Traqmate Analog Inputs
Anybody using Traqmate analog inputs via a DataII module to sample throttle plate position, intake air temp or MAP sensor outputs?
Wondering if the load impedance of the Traqmate has any negative effect on the sensor operation.
The only analog input I've been recording is throttle position. On the C6 with throttle-by-wire I actually spliced into the Dark Blue wire on the APP (Accelerator Pedal Position) sensor on top of the pedal.
In the screenshot below you can see I've got a window that displays RPM and throttle position. You can also see a window with the IO Data that shows the parameters I used to set it up.
I had no issues at all with any interference - the throttle works exactly as it did before tapping into that APP wire.
Bob
Bob
