Tire sizes for TTA
Tire sizes for TTA
I plan on running NASA TTA this year and 295 is the max tire size allowed (without adding points that would bump to TTS). So the question is whether to run Hoosier R6 295/35/17 or 295/30/18. Basically run fronts all the way around or rears all the way around? I've got 6 rears and 2 fronts right now. Not sure if I should just buy tires for the wheels I have or get more wheels.
Another option is to take my T1 bars off to get some points back and run Hoosier A6 in smaller sizes. 275/17 front and 285/18 rear (or 285/18 all around)
What do you think?
What do you think?
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Where you from? What region you going to be running in? There are many threads on this topic both here and on the NASA Forums. It seems that a 275 square set up is what is going to be tried this year, seems like a narrow tire for a C5Z maybe you should run TTS
Brian,
I ran 295/18 A6's square last year with T1 bars.
I changed to 275-18's square this year. I think the 275's are a little slower but would be faster than 295 R6's.
I would keep the T1 bars and go with 295 R6 or 275 A6. YMMV
John
John
I'm guessing yours is a ZO6?
275/35/18 square fresh A6's or C91's seems to be the hot ticket for TTA in the Southeast this year. Still room for sways and air filter.
You'll get more life out of 295 R6's, but you won't be as fast. I wish Hankook made C91's in a 295.
one other advantage with the 275's, a .4 hp/weight adjustment.
this allows you to run a C5Z at min weight, if you have any semblance of a healthy Z06, it would be hard to run it that light with 295s (no adjustment). Anything past 354 RWHP at min weight will blow 8.7 if you are running 295's. With the 275s, you can run about 20 hp more.
remember if you are down to 3118 you are taking .1 adjustment hit for being below 3200. you get .3 back with the 275s. nada with the 295s
@ 3118 lb essentially it's:
295's - 8.8:1
275's - 8.4:1
this is of course assuming your region is checking.
The C5Z is probably one of the few cars that's right on the line (most of them would be over) in bonestock trim running at min weight.
As the A6's age/wear the 275's make the car pretty loose when you are on the loud pedal, I like it because you really gotta drive it - and hard
295's - 8.8:1
275's - 8.4:1
295's - 8.8:1
275's - 8.4:1
295's - 8.8:1
275's - 8.4:1
I don't have the experience in various tire sizes, but I do have experience on A/R 6's. Used R's can be as fast as used A's for 1-2 laps (according to my data on R's vs. another drivers times on used As that I was racing against).
With that said, I would go with the smaller A's if it were me, and run away from R6's regardless of who tells you they are good..unless it's an enduro (maybe..)
I have an '02 Z06. I didn't think there was room for T1 bars AND A6 tires. This year the A6 are worth 13 points while last year they were worth 10. Here's my math so far:
The car starts with +7. sway bars are +2. A6 are +13, R6 are +10.
265 is -7, 275 is -4, 285 is -1, 295 is allowed, 305 is +1, 315 is +4.
So the winning formula is 295 R6 with sway bars (19 points)?
Or use stock sway bars and A6 tires, 275/17 front and 285/18 rear (or 285/18 all around). This is also 19 points.
That stuff about the .1, .2 hp for min weight stuff, I'm not familiar with that. Isn't that just for TTS, U, and R? I'm trying to stay in TTA.
So use T1 sway bars and 275 A6? That adds up to 18, woo it works! So if I leave my bars alone (leave the T1 on there) then it's either 275 A6 or 295 R6. cool.
So the weight thing... I ran TTS last year because I had 315 tires to burn through. My car was weighed once and was 3360 with my fat *** sitting in it. Does that mean they'll give me some extra points for being overweight? So I can have more horsepower to keep my ratio at 8.7 to 1 is what you're saying? I think I understand that, but there's no way to increase my horsepower without adding points and getting bumped to TTS is there?
Location: If you don't weigh in you don't wrestle Road America
Less weight will help your brakes, tires and wheel bearings all last longer, plus loosing weight is typically cheaper (to a point) than adding hp. Plus adding to cornering speed.
You're better off running the 275 vs the 285 because you will get a break of .4 on the hp and 4 mod points back.
What region are you running with?
Great Lakes Region, Mid-Ohio is my home track. Last year I was on really old 315 R6 with T1 sway bars and my best time on the pro course was 1:36.5. I was in TTS and never came close to free tires. This year I'm going to do TTA and hopefully win the occasional free tire. Gotta love Hoosier for dangling that prize out there!!
So if these are the three options, everybody votes for #3?
#1, use 295 R6 with T1 sway bars (19 points).
#2, use 285 A6 with stock sway bars (19 points).
#3, use 275 A6 with T1 sway bars (18 points).
Definatly look at #3, you have one point to play with that you could remove the cats or add a cold air intake.
Basically at 3360 you can make 386 rwhp with the 285's, you can make 404 rwhp with the 275's. Although I would get the weight down as much as possible, while still keeping the car streetable. (I'm assuming it's a street/track car.)
You may also play around with bars, you may like the smaller bars with the more narrow tires. This would open points up for shocks (+3).
Best of luck
Best of luck
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
