Couple Home-made fixes for a Camara mount & Vinyl Numbers
Old 03-03-2010, 12:43 PM
billy25us
billy25us's Avatar
Default Couple Home-made fixes for a Camara mount & Vinyl Numbers
Thought I would share a coupe easy fix's for an expensive camera mount and better looking numbers than painter's tape. The mount is a conduit holder from Lowes for 6 bucks already is tapped for the correct size all thread for a camera mount. And Numbers is spray painted on shelving paper . You can get as creative as you want with the numbers, I just put a couple cut out Jakes I printed on line behind the paper.
Old 03-03-2010, 02:24 PM
DaBullish1
Support Corvetteforum!
DaBullish1's Avatar
Two very good ideas. Thanks for sharing.
Old 03-03-2010, 02:41 PM
Aardwolf
Aardwolf's Avatar
Good idea!
I made an extended mount with plastic deck board:
I had the material left over from some other project. It's really tough but easy to work with.
Old 03-03-2010, 03:03 PM
flink
flink's Avatar
That is neat. I'm forever wrestling with my ioport mount (not the mount's fault - I'm picky).
Check out this Sony wide-angle lens from ebay for $25: http://cgi.ebay.com/ws/eBayISAPI.dll...m=200356305605. It came in a few days. Fits perfectly and I think it will improve the videos quite a lot.
Old 03-09-2010, 12:57 PM
billy25us
billy25us's Avatar
Here is a video shot with the mount. It seemed to hold up well.
http://www.youtube.com/watch?v=XiS0bhEvt14
Old 03-09-2010, 07:29 PM
USAsOnlyWay
USAsOnlyWay's Avatar
I threw this together quickly before a race. Actually works pretty well since you can play with the angle and aim of the camera pretty easily. Has held up to AutoX and long drives.
Piece of AL angle, muffler u-bolt clamp, hose clamp and a cheap short tripod. (15$ total...maybe?)
Not pretty but...
Old 03-09-2010, 07:42 PM
RedLS1GTO
RedLS1GTO's Avatar
I use shelving/contact paper for numbers and it works like a champ. Medium adhesive seems to work the best. I use white and just cut them out.
Old 03-09-2010, 10:57 PM
GeorgeZNJ
GeorgeZNJ's Avatar
St. Jude Donor '08-'09
That conduit holder is actually a water pipe clamp used for grounding/bonding the water system to the electrical system. Just trying to make it easier for people to know what to ask for at Lowes/Home Depot. Is the all-thread 1/4'' or 3/8" ? Very clever idea, thanks for posting it.
Old 03-09-2010, 11:20 PM
sperkins
sperkins's Avatar
Sweet. I just installed a full cage and was trying to figure out a way to cheap out on a new camera mount.
I used the same mini DVD camera forever with good results, but hated having to swap the 30min disc out after every session. It wasn't until I bought a new camera that I realized I could have put a memory stick in it.
Oh yeah and get a wide angle lens ($25 at Best Buy) - it's the bomb.
BTW - the all thread is 1/4".
To Couple Home-made fixes for a Camara mount & Vinyl Numbers
Quick Reply: Couple Home-made fixes for a Camara mount & Vinyl Numbers
