C6 '06 lower rear ball joint tear fix with VBP poly boots 31508
i tore the lower ball joint boot attempting to get it out to press in the a arm bushings.
I marked the camber position. the lower a arm is out.
Its as though the existing boot is attached with the ball joint. do you have to take a razor blade and cut it off flush with the bottom?
then fill the VBP 31508 new boot w grease and slide over and you are good?
thanks for the help
thanks for the help
