Trailer tires -question
I did a search in this forum on trailer tires and still have a question. It seems most guys are recommending 'D' load range tires and I understand the logic. But just based on the economics, I'd like to stay with 'C' range on my 16 ft open trailer (solid deck). I'm towing a C5 Z-06, I don't have a tire rack or tool box on the trailer (all that stuff goes in the truck). The trailer's original tires (Towmaster, 205-75-14) have performed great - just need replaced. Any thoughts on staying with the C load range - thanks
A Goodyear Marathon 205/75-14 trailer tire has a max load capacity of 1760 lbs. That's 3500 lbs per axle so if you have a two axle trailer, that should be OK. Going to a 215/75 tire will increase each tires load capacity by 100 lbs but you may need a 6" wide wheel.
D-range tires will have an even higher load range rating.
If you look at the Tire Rack website, they have a new Kumho trailer tire in the size you need with a D rating and 2270 lbs capacity. They run 65 psi instead of most tires that run 50 psi. They appear to be competitive in price to the Goodyear Marathons.
Make sure that whatever you get is rated "ST" for trailer use only; don't use truck tires or P-metric tires.
trouble is trailer tires fail often and for no reason, even when no where near there load rating. Most people like the added safety of the heavier load (more plies), yet even then they seem to fail.
However, having a few extra pounds of capacity may help spare the other 3 tires if one blows at high speed. If you are close to the limit with 4 good tires, and you lose one, you instantly overload the other three. Usually not a big deal, but having added capacity gives you a nice margin of error when things go wrong.
If you haven't had any problems get, what you are comfortable with.
I carry two mounted spares and have used both of them before.
What ever you do keep those suckers aired up.
Received 8,928 Likes
I have worn out three sets of trailer tires over 17 years and have never had one fail on me. Total weight of my 16 ft. trailer with the car and tires on it is 5500 lbs. I run the C rated tires. I bought a spare 11 years ago and am thinking I need to replace it due to the tire rotting. If I ever had to use it there might be a pop as soon as I let the jack down.
Bill
Bill
How long can you press 20 lb. over your head vs. 50 lb.? Your tire feels the same way. I have GY Marathons 15 D or E really never had one fail due to the tire. I recently had one bulge but caught it . I use the trailer for business all the time and have went through a few sets in 6 years with a lot of weight on the 10,000 lb trailer. Extra capacity is going to make it work less and last longer. All the money spent on cars here the trailer is not where to cut back. I just paid 130 mounted for a tire how much less could something else be? I rather skip a dinner out if need be.
Side of the road with traffic whizzing passed is no fun! DOT now recommends all tires be replaced after 5 years on all vehicles. I think we all check the tire pressure on the race car to much and the trailer to little! I have been shocked a few times what I have found on my own. Then the tire may be damaged even if you inflate it properly. Every time you get in the trailer to move it at least kick all the tires you will feel if one is soft.
And I totally agree: overspec the tires! Don't save a few bucks going with lighter load tires, as a highway blowout will potentially cost you a LOT more!
Using over rated tires Do not last any longer!!!....Period!!! They do compensate if you overload the trailer but they don't help that much if you blow a tire. Because you can't continue to tow with a flat tire anyway. The major cause of tire failure on trailers is, bent axels and spindles, also sharp turns tend to wear trailer tires. Other things on the trailer are rated for the carrying capacity IE" Axels, spindles, springs and bearings. Remember when you put 6000lbs on a 5000lbs trailer and hit a curb??? These are the things that create tire failure on trailers. If your tires are wearing out on the inside or cupping!! You have a bent axel or spindle. I assure you that if you are blowing or wearing out trailer tires you either have something bent or are towing overloaded!!!!!!! JD
Thanks for the input guys - it all makes sense and is the same logic that I would apply on the job - that's when I'm writing specs for others and OPM (other people's money)!!
Appreciate the the advice - Now I just need to work it into track budget.
Your right pop one tire and the remaining tire on that side is in real bad shape with the overload. Higher rating is better for potholes also.
Friend had a 7000 trailer enclosed and was going through 14" tires like crazy. He was towing thousands upon thousands of miles like NY to NV with a 58 Chev Cameo truck. he did 40-50,000 miles in one year. He went to 15" high load range and that was the end of his problems. Then he sold the trailers and went to 10,000 lb rating. High load range will take more abuse. I would never be caught on the no-name Chinese crap tires everyone is selling. He had the truck since 1960 and restored it to top notch award winning truck. GM offer to buy it 6 years ago.
Going up in tire size is not always the same as going up in tire rating. You can increase the capacity without increasing tire size. Going from a 14" to 15" will improve wear because the tire is turning less RPMs when going the same distance, it has very little to do with capacity. JD
As we all blow off super expensive track tires the trailer is not where I would cut back, Hoosiers 1400 and 3-4 days use vs trailer tires 520 years of use?
