PCM Relocation Pictures?
Old 03-08-2010, 12:07 PM
Pumba
Support Corvetteforum!
Pumba's Avatar
Default PCM Relocation Pictures?
Gentlemen,
Do any of you have pictures of how and where you relocated your PCM during the process of installing a dry-sump tank?
Old 03-08-2010, 06:12 PM
Pumba
Pumba's Avatar
Bump
Old 03-08-2010, 07:16 PM
MattB
MattB's Avatar
What tank are you using? I'd think that you don't have a whole lot of options for moving it as it has connections directly to the under hood fuse box and the TAC. If maybe you moved the wiring harness towards the fuse box you could move the PCM a little closer to the wheel well, but that is just guessing based upon some wiring work I did.
Old 03-08-2010, 07:45 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
http://forums.corvetteforum.com/c5-f...-dry-sump.html
Old 03-09-2010, 05:59 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
I will look and see if I have a picture of mine. It is moved to where the fuse box is. We made and enclosure to mount it in.
If I don't find one I can take one when I get home.
Old 03-09-2010, 06:31 AM
Pumba
Pumba's Avatar
Thanks!
Pictures would be a great help.
Old 03-09-2010, 06:37 PM
Wicked Weasel
Originally Posted by Pumba
Thanks!
I can take pictures, but I found this one I already posted. Not that close up, but you get the idea (actually a new picture might be in order since we now have it mounted in a box). I used the LPE relocation kit to relocate the battery to the trunk.
Old 03-09-2010, 07:36 PM
Pumba
Pumba's Avatar
Bob,
Thanks for the note.
I have my battery in the same Lingenfelter box in my trunk.
If you get a chance and can take a closeup of your PCM from the top, so I can see what you have done in relocating it.
Old 03-13-2010, 12:59 PM
Wicked Weasel
walking out to the garage today and taking pictures. I have to get something accomplished in this rain storm.
Old 03-13-2010, 06:45 PM
Wicked Weasel
If the power would come back I could actually post the pictures.
Old 03-14-2010, 12:08 PM
Wicked Weasel
sorry for the delay
Old 03-14-2010, 12:10 PM
Pumba
Pumba's Avatar
sorry for the delay
Bob,
Thanks for the pictures.
How did you get all those wiring harnesses to reach up there?
To PCM Relocation Pictures?
Quick Reply: PCM Relocation Pictures?
