Corner Balancing
Old 03-09-2010, 01:50 PM
Screamin Z
Screamin Z's Avatar
Default Corner Balancing
Anyone perform this on a C6 Z? Looking for tips and advice. First time getting it on the scales. Running Pfat coilovers.
Old 03-09-2010, 01:56 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
What is there to advise? As long as you have at least one adjustable end link on each axle it I'd straightforward.
Old 03-09-2010, 06:50 PM
outsideline
outsideline's Avatar
Default corner weighting
I would say you need to take it to someone who knows what
they are doing, & have digital scales. Also, you do need
adjustable end links.
Old 03-09-2010, 07:23 PM
68-427Rich
68-427Rich's Avatar
Have the car full of fuel, that's repeatable if you do this again. Make sure the scales are level. You will need to roll the car off, and back on the scales after you make an adjustment. Set the tire pressure. Have the driver with all his/her gear in the driver side seat. Disconnect one end of each bar. Use the wheels and tires you will be racing with.
Old 03-09-2010, 08:32 PM
Clarkfic
4th Gear
Clarkfic's Avatar
Default Clark
Bring your wrench to adjust the shocks and set the height of the springs
To Corner Balancing
Quick Reply: Corner Balancing
