Brake lines: Anyone still run original rubber on 2002?
Hi,
I've read here many a time that one of the first upgrades to the braking system is to change the rubber lines. Many also say they expected the pedal feel to change and it didn't.
Not expecting (or needing) the pedal feel to change---should I do this upgrade anyway just because my rubber lines are almost 8 yr old? Has anyone run lines that old w/race pads (ie hot!)?
Thanks for any opinions/experiences,
Andy
Andy
I have been running on my stock 02 lines and they feel fine, they are also in really good condition. I plan to upgrade here soon, but want to be sure I get the correct type as I have read a lot of threads saying that certain lines cause wheel speed sensor errors and require grounding.
I'm still on my original 02's. On the track I run Hawk DTC 70 pads/Stock rotors/stock calipers. I'm probably pushing my luck, but I've never experienced fade, or boiled the fluid. I've cracked pdas and rotors though.
Wow thanks George! You have a lot of track time! That's very impressive--I just went to race pads last year so I was not sure how long the lines handle the heat. Are you still on the original calipers or rebuilt or went to C6 calipers?
I run SS lines because everyone runs them in my race class. Great reason eh??? I have not found a set of SS lines I like because they all use round banjo fittings or a rube goldberg of multiple screw in fittings. The OEM rubber line uses a banjo block which is a DOT legal darn near foolproof design. IMO the best lines for stock calipers would be SS banjo block lines.
Hi,
Andy
Andy
On my '88 I was astounded at how much the line flexed. They were quite a bit older though! Grab the brake line and have someone press the brake pedal.
'00 Hardtop, almost 200K miles on original brake lines. 8 years of autocross, DEs, no problems at all.
One thing I've found is the pedal seems to get a bit lower as the pads get thinner. Not pad taper, I'm familiar with that and know the difference. Not bad fluid, this happens while on the street. Go from thin pads to thick pads and the pedal seems to get higher and a bit firmer.
Now, I don't have any scientific data to back this up, but IMO it must be related to how far the pistons are extended out of the caliper.
OK, folks, fire away.
Have a good one,
Mike
Have a good one,
Mike
Thanks for all the replies--I'm really kinda surprised!
I remember now that this was one of the big reasons why I've never upgraded--worried about issues w/ the fittings and installing them correctly. Is the install your issue w/the round banjo fittings etc? Or do they require service or something aggrevating that makes you not like the SS lines?
I think this is one of those "everyone does it and it's cheap" upgrades. I have never heard of an OEM line failure, and for me there was absolutely no change in the pedal feel.
I have seen it happen. The last time was last summer with a new C6 he was going into a turn at the end of a straight at 130 hit the brakes and the line blew. Luckily he is a very good drive and kept calm he was able to scrub speed off in the grass and mud before the wall. when he hit it was slow enough not to do any real damage.
My 02 hits the track 10 times a year, (Rd. Atl). I still use the OEM lines, (but have SS from MTI still in the box). I use the OEM caliber, disc with Hawk DTC-70 pads. So far, good results. (MY car only has 10K miles and is u ed 65% on the track these days.
Thanks for the replies, guys! Great info. here!
The 02 still has the original calibers. But that may change this year. I already have new disc as well as the afoementioned SS Lines. Last year was the first for running DTC-70. Before, I ran OEM and Hawk plus. Upon entering HPDE3, I made the swap. I bet that I am easier on brakes than most. Thinking of having both street and track set-ups in the future.
Flex the hose and you will see the rubber cracking if they are heading for bad shape. My front 01 Dodge dooley lines were cracked last year so I swapped them out. No clue why but one was really cracked and the others not at all. DRM lines are great if you decide to swap them.
Brake lines can also collapse inside with age. Funny thing is it happen on my big truck and fluid would go in fine but not release. The caliper would drag and get so hot it would near lock up. I was chasing a caliper problem as I thought it was lack of use on truck. Turned out I finally dumped the lines and it was cured. Nothing visible on the exterior to suggest the lines one way flow.
DRM or stock lines will not hurt so it may be time for the small price and the great importance of brakes.
