Need help with alignment settings
Old 03-10-2010, 07:15 PM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Default Need help with alignment settings
Hey guys. I'm curious about what kind of alignment settings you are using front and back. I run about 1 1/2' negative camber up front and about 1/2' negative camber in back. Caster and toe in up front still puzzle me. I'm not sure where to go with these. Any help would be appreciated. Oh, I run Kumho V710 tires. Thanks!
Bill
Old 03-10-2010, 07:26 PM
wallyman424
wallyman424's Avatar
zero your toe up front, 1/8 toe in for the rear. I'd up your neg camber in the front to -2, and max out the caster as best you can.
Old 03-10-2010, 09:08 PM
Solofast
Solofast's Avatar
You need about -1.5 in the back, or 1/2 a degree less than the front.
Old 03-11-2010, 07:27 AM
Bills Z06
Bills Z06's Avatar
Thanks guys!
Bill
Old 03-11-2010, 07:40 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I agree, but even -1.0 in the rear will help. I'd go with the OEM front toe, 1/32" or 0.1deg out. Makes the inside tire actually not fight against you in the turns.
Old 03-11-2010, 11:02 AM
FASST LN
FASST LN's Avatar
I read that any caster over 7.0 could cause your power steering pump to eventually fail.
My guy could not get over -1.5 camber on my fronts. I guess he would need to shim the A-arm support to go more negative? That is too advanced for me and my street tires though.
Old 03-11-2010, 11:31 AM
0Vector Vette
Former Vendor
Vector Vette's Avatar
Bill,
You didn't say if your car is a full time track car or do you still drive it on the street. My advice would be differant. If a full time track car, front toe out 3-4mm, rear toe in 1-2mm. Camber up front negative 2.5, rear as much as you can get. If driven on the street, these settings would wear out your tires prematurely. Front toe out 0-1mm, camber around 1.5 negative. Rear toe in 0-1mm, camber around 1 negative.
Old 03-11-2010, 11:51 AM
davidfarmer
if you need more camber, you REMOVE any shims/washer behind the upper control arms. Often there are 2 from GM, although sometimes there are none
To Need help with alignment settings
Quick Reply: Need help with alignment settings
