Engine building service available
Supporting Vendor
Phoenix Performance has opened its in house engine building services division.
Specialties include building and rebuilding of all GM LS engines, including LS1, LS2, LS3, LS6, LS7 and LS9... Plus all of the older Chevy Shortblocks, short rack and carbeurated engines.
Capabilities include full machine shop expertise, including CBN Cutter technology to quickway boring and honing, sunnen rod reconditioning, heinz balancing and crank shaft grinding.
Full assembly and blueprinting available by engine specailist with over 25 years hands on experience...
All work is custom done to customers specs.
Call for information and to discuss your personal requirements...
610-482-0141 jfaphoenix32@aol.com
Supporting Vendor
First two orders for ls3's in the books...
Call if you want to discuss your project. Will rebuild ls6's and Ls1's, as well as upgrade heads and cam packages...
Install service available also...Along with suspension and track day setups...
call Joe 610-482-0141
Supporting Vendor
Thanks for all of the calls... We have 4 ls engines underway and can do more, so if you need some help, just call.
610-482-0141
610-482-0141
Supporting Vendor
call with any questions... All work is guaranteed...
we also do removal and installation, as well as custom tuning...
610-482-0141
610-482-0141
