Brake question
Brake question
Hey guys,
Installed some Wilwood calipers recently and noticed even after bleeding the system the rubber underside of the brake cylinder cap keeps "extending" out. Is this an indication that there is air in the system still?
I experienced something similar with the clutch cap a few months back and it turned out air was in the system.
I did have a leak at one of the SS lines I installed but corrected prior to seeing it expand again. hmmmmm...... have to look around again but while bleeding I didnt see any leaks at any corner. It was a pretty noticeable leak the first time.
So, is it safe to say when it expands thats a leak? Only way to see if there is air in the system is to bleed?
