Which camber gage for C5Z
Which camber gage is recommended for a C5Z? Longacre has several, magnetic, one with a GM adapter, and fancy ones with "quick set".
I'm hoping one of the $100 - $150 ones will work ok and will also work OK on my DD (a Subaru). Thoughts?
Thanks,
Chris Shay
Thanks,
Chris Shay
I lay a bunch of towels under my Longacre when I use the magnet base.
The Smart Camber is insanely overpriced. You can build one using the Sears digital level with a bit of aluminum angle for about $50. I did just because I bought The Sears level for other things. I built a frame like the Smart Camber.
The Sears level is dead on with both the Longacre and the Smart Camber.
I have both smartcamber and longacre bubble level. The smartcamber is nice because it can be used anywhere, but I still use the bubble level when I can. It's hard to screw up a bubble. The catch is that the car must be on a level plane. The above longacre adapter does not work on 18" diameter wheels. At least not on my CCW C10's. It's just not big enough. What I did was cut a 2"x2" length of square tubing. I lay it flat against my wheel/tire and stick (I use the magnetic adapter, but not necessary) my bubble level to it. Works very well. A piece of aluminum would be easier to move around because of weight, but the guage must be held on.
Received 8,926 Likes
--Dan
Location: If you don't weigh in you don't wrestle Road America
For the money ($119 @ Amazon) I'd buy a 24 inch electronic level with built-in laser. I use my 20 yr old Smart Level (now M-D BP) left over from contracting days but purchased a separate laser to shoot thrust angle. This way you can get both at once. Plus, you can build a garage with it.
--Dan
--Dan
Bill
