Cross-drilled/Slotted or What?
What is the better... plain or slotted or drilled rotors for the track..(road course) I go 5-6 times a year. 09 C6 Z51 procharger 500rwhp
trapp
I currently run with the Z51 package rotors and HP plus pads, dot 4 with braid steal lines...and ducts.
Reason that I ask is because in Mits Evo X forum (I have a Evo X GSR 2010) the road racing guro's stated never get slotted or drilled!!.
Any input is welcome.
trapp
trapp
trapp
solid is my first choice, slotted works well also. Drilled will crack sooner, as they tend to start cracking from the holes, and you often get strange wear patterns around the holes.
AFAIK napa does not sell blanks in Z51 sizes.
HP+ pads are not supposed to be used at temps higher than 800-900. make sure you are not cooking your pads.
slotted rotors are fine for track use.
I used hps pads last year so I would think HP plus would be better....we will see..
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
A lot depends on your driving style and the track, what works for me with HP+ at LRP probably won't cut it at road Atlanta.
-Dan
correct, but IMO a bit overkill if you are on street tires, they can lock up pretty easy, and my biggest complaint is the bits of metal, pad, etc that ruin the rims. Just an FYI, don't use these if you are fussy on the street rims, give them a sacrificial set of track rims (and sticky tires).
-Dan
-Dan
4886700 & 1 Front
4886702 & 3 Rear
My last event, I cracked the rear on the outlap, Serious cracks in 5 places up to the hat. Lucky it did not come apart on me. Felt fine the previous session and when coming in.
I am going to be looking for alternatives.
