Polyurethene How much of a nighmare to change?
Well the Title says it all. Polyurethene How much of a nighmare to change? Have you done it and how bad was it?
mostly just takes patience. I drill them out and then just push them out. If you have a press, I'm sure it's much quicker. Takes a while, but not "hard" about it.
Former Vendor
I would say just be careful removing the old ones from the aluminum A-arms. If you don't feel comfortable, let a machine shop do it. It won't cost much. Putting the new ones in is a snap.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
C5/6 I have been using Vette Brakes units. The Energy Suspension pieces want you to re-use all of the stock metal sleeves which is darn near impossible.
Install is cake, make sure you have a press, and a saw of some sort to cut the ends off of the lowers. That made it the easiest for myself to do them.
I have VBP units in stock if you need a car set of bushings.
installed the Pfadt (latest version) kit recently.
the only tough part was getting the 1 pc (large) lower rears pushed in (I need a better press). otherwise, removing the old and the 2 pc ones were easy
i did the full pfadt kit with only a vise. piece of cake, although like drivinhard said, one of the rears was pretty tricky. it'd probably help if you chamfer the leading edge just a tad. you'll know which one it is when you get to it.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
FWIW, make sure to use the correct type grease and apply it in the right areas. Perhaps you know this already, if not, search for information because there are various sites that are very helpful.
Terminal Vette Addict
http://forums.corvetteforum.com/auto...e-learned.html
goto the suspension section and read on the pfadt set up.
It was a pain, the VBP one is a ton easier
