Anyone tried a Cool Shirt?
Old 04-11-2010, 03:15 PM
BERETTA
Support Corvetteforum!
BERETTA's Avatar
Default Anyone tried a Cool Shirt?
Has anyone tried one of these Cool Shirts? Do they work and which models have you tried? It is getting hot outside! Thanks!
Old 04-11-2010, 03:21 PM
Short-Throw
Short-Throw's Avatar
I run them in both my cars when extremely hot and during Enduros. The hooded shirt is great during extreme conditions. The secret is mixing the correct water to ice ratio so you get cold flow for the entire session/race.
Having a cooler mounted in your car saves time strapping down the portable unit.
Adding a helmet mounted intake for cool air and a drink straw completes the package!
Mike
Old 04-11-2010, 03:34 PM
BERETTA
BERETTA's Avatar
Mike
Thanks-I think I am going to get one, I did not run any late spring or summer events last year, I plan to run some events in May-June and late summer-(hopefully Autobahn in June!)
Old 04-11-2010, 04:36 PM
eogel
eogel's Avatar
I use a FAST cooling system which cools the shirt (cold water) and helmet (cold air). Would not consider racing in hot weather without it now. It has an amazingly positive effect and prevents concentration failure due to the heat.
Ed
Old 04-11-2010, 04:54 PM
BERETTA
BERETTA's Avatar
Ed
Thanks! I just checked that one out, that may be the way to go, that setup definitely looks like it could spoil you. Since I have gotten older the heat is a little harder to handle....
Old 04-11-2010, 05:28 PM
AU N EGL
AU N EGL's Avatar
50% / 50% water to alcohol keeps cooler much longer,
Plus I use block ICE and cubed ice
Old 04-11-2010, 05:51 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
used them in race boats. most important part to cool is your head. Keeps you thinking straight.
Old 04-11-2010, 06:54 PM
WNeal
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
You mean cool pants then right ?
Old 04-11-2010, 08:25 PM
eogel
eogel's Avatar
Look for a used one, then all you need to buy new is the shirt and whenever you are ready, a helmet with fitting to accept the cold air.
That is what I did.
Ed
Old 04-11-2010, 09:51 PM
JDIllon
JDIllon's Avatar
I use one all of the time in hot weather. If you decide on the one with the hood? Besure to make sure that it will go under your helmet comfortably. If your helmet fits snug the hooded coolshirt makes it to tight. Just a heads up!! JD
Old 04-11-2010, 10:15 PM
johninar
johninar's Avatar
One of the best investments I've made. Oklahoma in July is well toasty.
Old 04-11-2010, 11:12 PM
Bimota Guy
Bimota Guy's Avatar
I race at So Cal desert tracks. They work great. I use the un-hooded shirt and the 12-qt cooler.
Old 04-12-2010, 09:26 AM
Falcon
Falcon's Avatar
A Cool Shirt and cooler, as Karl Malden said...
"Don't leave home with out it!"
Old 04-12-2010, 12:16 PM
sothpaw2
sothpaw2's Avatar
Really? It's been warm here for a few weeks but at work we still have our snow mound in the parking lot since it was several stories tall in Feb.
Old 04-12-2010, 02:30 PM
ryan0
ryan0's Avatar
best invention ever brought to racing.
Old 04-12-2010, 09:43 PM
BERETTA
BERETTA's Avatar
Thanks everyone for all the replies and suggestions..
Old 04-14-2010, 07:06 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
We ran them in all of the TransAm and World Challenge cars.
The ALMS car of course used A/C during most of it's career.
I do have smaller systems for guys to pop in and out of their cars, especially if you are using them as dual purpose.
http://www.lgmotorsports.com/catalog...oducts_id=1575
I have these in stock as well.
Old 04-14-2010, 07:28 PM
waktasz
waktasz's Avatar
I have used the kind that has freezable inserts that you stick in the shirt. They stay cold for about an hour. You can stick it in a cooler of ice water and it will "freeze" at 50 degrees and stay solid (and cold) for a while.
Old 04-14-2010, 08:37 PM
ssdeuce
ssdeuce's Avatar
So add Jack Daniels with your water for your drink straw? Doesn't sound safe.
To Anyone tried a Cool Shirt?
Quick Reply: Anyone tried a Cool Shirt?
