Painters Tape
Old 04-12-2010, 05:24 PM
Dan Wendling
Dan Wendling's Avatar
Default Painters Tape
I am going to my first HPDE at Summit Point this weekend and wonder about protecting the finish with Painters tape. Is this really important at an HPDE 1 event?
I plan to have clear body protection installed but I am now wondering if it will get torn up at HPDE events and I would be wasting my $$.
What is the best plan? Both clear body protection and tape? Tape only? or other??
Old 04-12-2010, 05:42 PM
CodeBlack
CodeBlack's Avatar
Some members including myself use clear contact paper, the same kind that's used to line your cabinet shelves with. You can get it at Walmart.
Old 04-12-2010, 06:08 PM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
Or this:
http://www.buyroadwrap.com/
Old 04-12-2010, 06:45 PM
gmccreary
gmccreary's Avatar
I use Scotch no residue duct tape. It releases with no problem and it is thicker than painter's tape. I do recommend some sort of protection. I wish I could have taped the windshield since I took a nice chip at Road Atlanta a month ago.
Old 04-12-2010, 07:06 PM
Zenak
Terminal Vette Addict
Zenak's Avatar
I only do the mirrors and the leading edges of my lights. if you hpde you gonna mess your car up. if nothing else vulcanized rubber all over the car. Bitch to get off too.
I got the C5 creations mirror protectors i throw on in like 2 secs on the mirrors when i hit the track now because taping is a pain in the ****.
Old 04-12-2010, 07:51 PM
Z11409
Z11409's Avatar
http://en.wikipedia.org/wiki/Gaffer_tape. No residue to remove
Old 04-12-2010, 07:57 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
FATT or the PCA event? I'll be at the FATT so hope to see you there. I have the clear body protection and it works but ironically is even harder to get the rubber streaks off of.
Old 04-12-2010, 10:00 PM
aspeters
aspeters's Avatar
This weekend at Summit is a NASA event. I'll be there running #18, black C4 in HPDE3. Lookin' forward to hangin with everyone...
-Andy
Old 04-13-2010, 12:08 AM
dfinke23
dfinke23's Avatar
Have you found any trick for easy removal?
Old 04-13-2010, 01:08 AM
RedLS1GTO
RedLS1GTO's Avatar
Is it at Summit Main? Has anybody been there this year to see if they fixed it? At the end of last season it was like driving behind a gravel truck if you were behind somebody because of the track coming apart.
Old 04-13-2010, 01:16 AM
Blurr
Blurr's Avatar
I use Turtle wax bug and tar remover seems to work well
Old 04-13-2010, 06:29 PM
05C6GAC
05C6GAC's Avatar
Old 04-13-2010, 06:38 PM
gmccreary
gmccreary's Avatar
Ready for Roebling Road this week end. No residue duct tape.
Old 04-13-2010, 08:09 PM
RedLS1GTO
RedLS1GTO's Avatar
Why not the headlights too? If you are going to cover it... might as well save them too!
Old 04-13-2010, 10:48 PM
gmccreary
gmccreary's Avatar
Might be dark before I get to the track. I'll cover them before I go out.
Old 04-13-2010, 11:23 PM
bluemagoo
bluemagoo's Avatar
I use a little WD40 on a soft cloth to remove the rubber streaks. Quick & easy on both painted and 3M film surfaces...
Old 04-14-2010, 07:10 AM
Kanmer
Kanmer's Avatar
Cruise-In VI Veteran
They have repaved the main sections with quality materials this time. I will be there for NASA as well. The over the hill gang will be there
To Painters Tape
Old 04-14-2010, 07:18 AM
RedLS1GTO
RedLS1GTO's Avatar
I won't be out there for this one but I would love to get back there sometime soon and drive without chunks of pavement flying at my face the whole time.
Old 04-14-2010, 09:24 AM
Bill32
Bill32's Avatar
Yep, been using WD40 on all the cars for many years. And Quick Detailer or Quick Wax after the WD helps even more.
The trick with tire marks is to remove them before they harden. It's much easier to remove them at the track (or in between sessions) than to wait until you get the car home and let it sit for a day or two. It's at least 3x harder to get them off after they've sat for a while.
And WD contains no silicon so, it won't interfer with a repaint.
Old 04-14-2010, 07:37 PM
05C6GAC
05C6GAC's Avatar
Look fordard to seeing you out there. it'll be good with some vetts out there!!!!!
Quick Reply: Painters Tape
