TMPS sensor delete question
Old 04-14-2010, 11:01 PM
catwood
catwood's Avatar
Default TMPS sensor delete question
If I get wheels without them will the car go into limp mod or just have a light on the dash?
2001 Zo6
TIA
Carl
Old 04-14-2010, 11:24 PM
darguy
darguy's Avatar
My understanding is that for C5's they make no difference, and for C6's they do. I ran with malfunctioning rear sensors for 1.5 years on my 99 without any codes or lack of active handling/comp mode/traction control/abs. Just the warning on the display.
Old 04-14-2010, 11:34 PM
catwood
catwood's Avatar
cool thanks. I'm new to the vette word and am not used to all these electronic aids.
I just want to mod and track the car
Old 04-14-2010, 11:54 PM
GettReal
GettReal's Avatar
I havent had TPMs in my car for years. You will occasionally get a message on the DIC that indicates no readings... but nothing happens to the car... you can just press reset and they will go away for awhile until the computer realizes again they arent sending info. No big deal though... enjoy
Old 04-15-2010, 12:20 AM
joemoia
joemoia's Avatar
production C5 Z06's were delivered without the TPM system activated. Production tires were Goodyear F1 Super Car (non-runflat) & the wheels had no sensors installed. The TPMS could be activated by an owner using a tech 2 to activate the system and installing sensors on the wheels.
Old 04-15-2010, 10:46 AM
Pylons
Pylons's Avatar
on a C6, you will eventually get to a point where you can no longer turn off both active handling and traction control...you'll only be able to turn off traction control
To TMPS sensor delete question
Quick Reply: TMPS sensor delete question
