07Z06 Track car - Chassis/Suspension greeze points
Old 04-17-2010, 01:49 PM
Coldmale
Coldmale's Avatar
Default 07Z06 Track car - Chassis/Suspension greeze points
Over the past month the squeeks and groans from below have become unbearable.
I suspect either the shocks (new pfadt units just 3,000km past), or the stock chassis/suspension
I use the car in 30deg C+ heat and for track use, so the joints get a real pounding
What goes first? Where should I look? What is going to fail?
Thanks for your input
John
Old 04-17-2010, 03:09 PM
AU N EGL
AU N EGL's Avatar
I would put the car on jack stands or a lift, take all four wheels off and check each of the suspension bolts. Some may have loosened
Old 04-17-2010, 03:26 PM
longdaddy
longdaddy's Avatar
there should not be anything to grease. i would start by disconnecting the swaybar links and see if that makes the noise go away.
Old 04-17-2010, 04:06 PM
thebrander
thebrander's Avatar
Before you do anything, make sure it's not the exhaust hanger springs (holding the exhaust up at the mid-section of the car). Go shake the exhaust up and down and see if that's the squeak. Mine were squeaking pretty bad when I went over any sort of bump. I just greased them and put a small rolled up piece of thermal tape inside them to add some damping (don't know how long this will last, but it fixed the problem).
Old 04-17-2010, 05:25 PM
imp zog
imp zog's Avatar
The main creaking that I've gotten from these cars is the swaybars in the bushings that attach to the carrier. Disconnect the ends and slide the bar to one side, put some grease on the bar right by each of the bushings, and then slide it back and repeat on the other side. Slide it back and forth until there is lots of grease inside the bushings and then re-attach the ends. Wipe off the excess and you should be less creaky.
Old 04-18-2010, 08:36 AM
Coldmale
Coldmale's Avatar
ttt
common guys - I would have expected more input on this?
Is this not a common occurrance?
Old 04-18-2010, 12:26 PM
longdaddy
longdaddy's Avatar
Originally Posted by Coldmale
ttt
You've already checked all 4 things that were suggested?
Old 04-18-2010, 12:49 PM
Coldmale
Coldmale's Avatar
I'm afraid so. Had already done that before I asked.
The exhaust was my first bet, so I welded it up, but made no fifference
I suspect the shocks, but I dont know how to do anything about it
John
Old 04-18-2010, 01:07 PM
Z11409
Z11409's Avatar
did you grease the two rear only tie rod ends near the rear rotors?
Old 04-18-2010, 01:46 PM
Coldmale
Coldmale's Avatar
No - will that be a case of removing a rubber boot?
Old 04-18-2010, 04:43 PM
bluemagoo
bluemagoo's Avatar
Here's a link showing what you're looking for. These grease fittings are not found on the non-Z51 base Corvette.
http://www.nakidparts.com/id47.html
Old 04-18-2010, 10:12 PM
Blurr
Blurr's Avatar
No. you should have a zerk fitting at each end. Don't put too much grease in or you'll have it all over the wheel barrel.
To 07Z06 Track car - Chassis/Suspension greeze points
Quick Reply: 07Z06 Track car - Chassis/Suspension greeze points
