C6Z Front Shim affect on camber?
Does anyone know approximately how much camber each shim is worth on the top control arm? I am removing some for more camber.
Thanks in advance.
Bob
Thanks in advance.
Bob
I think each shim is approx 1/2º, assuming you remove one from each bolt. I'm pretty sure I took 2 from each arm and went from -1.2 to -2.2, then later put a thin shim back in to get down to -2.0.
Someone else had a post on this more recently and may correct me if I'm wrong. btw, be carefull with the threads in the frame. If you damage them, you will regret it.
I agree. I usually take two out to go from -1.4 to -2.3. Last night I took an extra one out to get to -2.8. I'm not sure if my washers are the same thickness as the factory ones since I'm running a camber kit.
BTW, I reset the toe but as long as I am removing an equal number of shims from each stud should it affect the caster?
no, as long as you remove the same number from all 4 bolts, the upper balljoint does not move fore/aft relative to the lower ball joint, so the castor does not change.
Washers
A word of caution -- I mic-ed a handful of hardware store washers and their thickness varied by quite a bit. If you're trying to be precise check the ones you're using.
--Dan
--Dan
the average washer is made from scrap and that is why the vary. If you want consistent thickness buy graded washers like graded bolts.
Right, but as I only use washers to set caster or compensate for L/R differences I can fine tune it better with the varying thicknesses and then use a set number of shims to add and remove camber as needed.
Former Vendor
