Lightest spring recommended
Old 04-19-2010, 10:25 AM
robz
robz's Avatar
Default Lightest spring recommended
I'm trying to determine the lightest FRONT spring that I could use for a coilover setup that would work for a stock weight c5Z06. This will be for drag racing.
I want to make sure the light spring i choose will be enough to maintain ride height and hold up the car. Any thoughts or experiences?
The standard spring rate for the setup is 285lbs/in and it's designed for a c5corvette.
Old 04-19-2010, 12:24 PM
J.R.
J.R.'s Avatar
You might want to call Pfadt. I believe they make a drag racing/street coil over setup.
www.pfadtracing.com
Quick Reply: Lightest spring recommended
