What seat mount works on a sparco evo II?
Old 04-22-2010, 10:01 AM
Red5
Red5's Avatar
Default What seat mount works on a sparco evo II?
I had an aluminum set up that was hand made. It's not very good. Is there a simple fixed unit that fits the seat bolt pattern of a c5? Does anyone have a mount / bracket they want to sell?
Old 04-22-2010, 10:10 AM
tcmc5
tcmc5's Avatar
None better than Hardbar.
Old 04-22-2010, 11:58 AM
PA Z06
PA Z06's Avatar
I have a hardbar, and its great. Also customer service is fantastic, Gary stands behind his products.
Old 04-22-2010, 12:24 PM
MYRX
MYRX's Avatar
Mine came from PFADT. Perfect fit. I recall their illustration shows the seat mount with a Sparco seat as well.
Old 04-22-2010, 12:51 PM
brkntrxn
brkntrxn's Avatar
I just installed Evo II's in our C5Z06 and I used the Sparco mounts.
Plug and play for the most part. I did make an adapter plate on the passenger side (couple of strips of steel) so I could position the passenger seat farther back than the Sparco mount allowed. If I have a passenger with me, I don't like their helmet being in my line of sight if I have to look out of the passenger window.
-Kevin
Old 04-22-2010, 05:48 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
hardbarUSA.com
Old 04-23-2010, 09:13 AM
Van Steel
Premium Supporting Vendor
Van Steel's Avatar
Hard Bar, others have copied Gary's part..
PL
Old 04-23-2010, 12:39 PM
TS Motorsport
TS Motorsport's Avatar
I have a sparco pro 2000 with sparco aluminum side mounts to a custom made base.
Old 04-24-2010, 06:57 PM
gintama
gintama's Avatar
+1 for either Hardbar or PFADT with a Evo II. The PFADT is great because it gives you the option to mount sliders.
To What seat mount works on a sparco evo II?
Quick Reply: What seat mount works on a sparco evo II?
