WTB: XR2 front C5 size pads
Old 04-23-2010, 04:39 PM
Zenak
Terminal Vette Addict
Support Corvetteforum!
Zenak's Avatar
Default WTB: XR2 front C5 size pads
WTB: XR2 front C5 OEM Caliper size pads
I need a set of XR2 pads in 50% or better condition for C5 stock calipers if anyone has them for sale. I will need pics to make sure they arent tapered etc.
I have rear left, need fronts to match them.
Old 04-23-2010, 08:15 PM
drivinfast
drivinfast's Avatar
will these work
front & rear Cobalt XR CRB.GTS.D732/731
if so link is here
http://forums.corvetteforum.com/c6-p...nt-rotors.html
Old 04-24-2010, 08:27 AM
Zenak
Zenak's Avatar
The C6 Z51 is a larger pad than stock C5/C6 sadly... Or ID hop all over that
Old 04-27-2010, 06:52 AM
Zenak
Zenak's Avatar
Ttt
Old 04-30-2010, 04:38 PM
Zenak
Zenak's Avatar
ttt
Old 05-03-2010, 12:15 AM
tdelena
tdelena's Avatar
St. Jude Donor '12, '14-'15, '17, '20
C6 Z51 uses the same pad size as C5, C5Z and C6. 731/732 is the correct size.
Old 05-03-2010, 11:57 AM
0Vector Vette
Former Vendor
Vector Vette's Avatar
Zenak,
Those pads that are for sale are not XR2 compound. GTS is the old name for the compound now called CSR. If you can't find used ones, we have new in stock.
Robert Finlayson
Performance AFX Motorsports
815-254-2631
To WTB: XR2 front C5 size pads
Quick Reply: WTB: XR2 front C5 size pads
