front rotors in rear with rear stock calipers
can it be done? can the rear caliper handle stopping the bigger rotor?
just curios because i have front spares hanging around and my rear rotor is toast... dont reallly care about parking brake option, its hardly used
thanks
thanks
Try DBA rotors.... they are 2x the cost of rear rotors, but they last 4-5 times as long.
I know that KNS brakes can get them (and he is a vendor)
Past that, if you are looking to run fronts in the rear, you'd need a new bracket at the very least.
new brakets are a cinch, its just an adapter to align things. The parking brake is more of the issue. I guess we should search on the system, but I have read somewhere that it has its own shoes, can't recall if that is my new car or my old subaru....
I too like this option, as the rears are so tiny, the more mass there the better for cracking. The brakes (Calipers, pads) seem to be fine, but the rotors seem to have little margin built in for the heat tolerance road racing provides.
Former Vendor
Front rotors are 1.26" thick, rears are 1.025" thick. Even with some type of adapter, the rotor isn't going to fit in the rear caliper. If you are talking about putting front calipers on the back, then it can be done simply. However, it doesn't work as the front caliper has too much bite and the balance is way off.
If you are looking for a better rear rotor, we make a 2 piece rear rotor with or without the parking brake. We use Coleman rotors and machine the hats ourselves. Our rotors are 100% made in the USA, directional, direct fit replacements, slotted only - no holes, and weigh significantly less then the stock rotors. For example, the rear without the parking brake weighs just over 9.5 pounds.
If you are interested or have any questions, give us a call at 815-254-2631.
Robert Finlayson
Performance AFX Motorsports
Robert Finlayson
well there goes that idea. I just ordered new rear rotors thanks for the responses. so I cant use front rotors on the rear unless I have front calipers there as well, and that will probably throw out the master cylinder performance so Ill just keep it stock and grin and bear it. im trying xp10's on the rear so I hope they last...for a while.
Robert Finlayson
Robert Finlayson
FWIW, I put the front calipers and rotors on the back of my C5 for track use only and the master could not keep up.
Robert Finlayson
Robert Finlayson
PM me with price please.
I have an 03 z06 with stoptech fronts, and stock rears. Planning on using XP10/8 pads, with 220utqg for the first half of the season, until they wear out, then ra1's or r888's in about a 295/18 square pattern.
