PFC99/XP8 mix - good idea?
Car is stock 2007 coupe Z51 on street tires. Over the last 3 HPDE seasons, I have progressed from absolute beginner to intermediate. For brake pads, I went from C6Z51 to Hawk HP+ to C5Z06. I need to find the next level up, especially since I may go to better tires (R888?) soon.
At $115, PFC99 sold by MBS is an attractive option for the front. Unfortunately, PFC rear are only available in Z (not good enough?) or 01 (too good compared to 99 fronts, not cheap).
Many people like the Carbotech XP10/XP8 combo. XP8 seems to be a semi-affordable option and good rear for intermediate HPDE drivers.
I'm thinking about doing PFC99/XP8. Good mix? Bad idea?
I'm running that exact combo now.
PFC99 front w/XP-8's on the rear. c5z calipers, SS lines, cooling ducts and RBF 600. Im not a fan of the PFC 99's compared to the XP-10s I was using before. I think they don't have as good of initial bite or modulation as the carbotechs. seems like they trail off too quickly after that initial stomp, you have to brake a little harder for longer to slow down, if that makes sense. that said they also don't seem to work too well with XP-8's in the rear, but I wouldn't fault the PFC 99 pads for that. I found my rear was dancing a good bit while slowing down off the straights.
On the good side, they don't make a lot of noise for street driving, the dust comes off easy and they seem to be pretty rotor friendly. I'm just about done with my front set and didn't have to change rotors at all. usually with carbotechs I get 2.5-3 days out of a set of rotors until they crack on me, pads will last about 3-4 days depending on how brake intensive the track is. I got 4 full days out of a set of PFC-99 pads and rockauto rotors... I think thats a record for me.
How would you describe your skill level? Do you do a handful of HPDEs/year, or actual racing every weekend?
Do you think the XP10 is better enough to warrant the price difference with the PFC99? Looks like $192 vs $115, which is significant.
Did the XP8 rears work better with XP10 front, or do you just plain dislike XP8 rears in all combinations?
Terminal Vette Addict
Far worse in fact. Since the XP8 has a larger bite than the PFC99, you wind up with a slight rear brake bias which makes the back end likely to feel fish tailish. Marc (AlwaysinBoost) gave an excellent write up.
If you put XP10 in the rear which has more bite and more torque it will just magnify the problems, since the XP10 grab harder than the XP8.
Thanks for the great information!
I really like the XP-10's. I only tried the 99's cause of the great deal you mentioned. IMO they are worth the price difference.
the xp8's work better with the xp10s up front compared to the 99's, but I think next time I'm going to try xp10s all around to get more rear bias and see if I can cut down on the front pad usage.
If you're thinking about carbotechs you should call them up and tell them the tires you're running, cars weight/power and your skill level and they will recomend a pad for you. everyones opinion is different. for the price of the 99s I think its worth a shot. if you decide you hate them you can always bring them with as a backup pad incase you chew up your race set.
