Eastcoast Performance Has You Covered>>>Supercharger Kits/Axles/Clutches/Couplers!!!
Old 05-07-2010, 11:22 AM
0Mike Yeager@Eastcoast Performance
Former Vendor
Mike Yeager@Eastcoast Performance's Avatar
Default Eastcoast Performance Has You Covered>>>Supercharger Kits/Axles/Clutches/Couplers!!!
Hey guys, as alot of you know we here at Eastcoast Performance-Corvettes have over 28 yrs Experience on Corvettes, plus we keep up to date with all the Newest parts that are available for the C5 & C6 vettes....We have some unbeleiveable deals for 2010, for any of your Corvette needs...
Just call me directly and ask for Mike Yeager and I will make you a special deal on what ever you want to buy at the time, and you can do this every day for the hole year of 2010, if you want....So just call and get your special deal....YES Basicly You make your own deal...!!!
Extra Special Deals on What you need...!!!
C5 Remote Clutch Speed-Bleeder Kit $59.99 w/Clutch Purchase
C6 Remote Clutch Speed-Bleeder Kit $69.99 w/Clutch Purchase
ARP Flywheel & Pressure Plate Bolts Both $49.99 w/Clutch Purchase
TORQUE TUBE ACCESSORIES...
Torque Tube Bearing Kit (3 Bearings) $199.99
10mm & 12mm CNC'd Billet Aluminum Torque Tube Couplers, The units we make are Truely BALANCED...!!!
10mm $139.99 each
12mm $145.99 each
(the good ones, these say Made In Germany)German 10mm Rubber Couplers $79.99
(the good ones, these say Made In Germany)German 12mm Rubber Couplers $79.99
C5 Accessories....
C5 Z06 Clutch Master Unit $79.99
C5 Z06 Clutch Slave Unit $99.99
LS1 & LS6 HD Pilot Bearing $12.99
C6 Accessories...
GM C6 Z06 Clutch Master Unit $129.99
GM C6 Z06 Clutch Slave Unit $189.99
LS2,3,7 HD Pilot Bearings $18.99
ECPCorvette has started to release some of its Aluminum Billet Products...!!
**Air Tube Block Off Plates for Headers or Block offs for Air Tube ends**...
We have them instock ready to ship to you..!!!
Wholesale Prices are $19.99 each or $35.99 pr....Limited Time Offer.!!!
***We also have the 10mm & 12mm CNC'd Billet Aluminum Torque Tube Couplers, The units we make are Truely BALANCED...!!!
10mm $139.99
12mm $145.99
The Mikey Did It Again Special...!!!
Russell Stainless Braided Brake Line Kits....
ALL C5's & Z's 97-04 $99.99
ALL C6's & Z51's 05-09 $99.99
ALL C6 Z06's & Grand Sport 06-10 $99.99
The Best Clutch & Brake Fluid, Motul RBF600 $19.99 per pint
AXLES
These are very Strong Axles under $2300....These are Brand NEW Replacement C5 Z06 CV Axles w/ 1 year Replacement Warranty, if it breaks, we replace it with a New Axle..
These are a must in any C5 or C6 thats has Mods done....
We have about 200 sets of these axles out right now, and most have been sold to Corvette Forum Memebers who are enjoying the New Stronger CV Axles...They are on the road in C5's & C6's and Z's, they have been beat on and raced In Corvettes ranging in HP & Tq from 400-1237....
$399.99 per pair..!!!
LS7 NEW Clutch Kits(Flywheel,Disc,Pressure Plate & Alignment Tool) $429.99
C5 Z06 LS6 Clutch Kits (Flywheel,Disc,Pressure Plate & Alignment Tool) $399.99
10mm $139.99 each
12mm $145.99 each
C5 Accessories....
C6 Accessories...
Special Prices For 2010
ALL of our clutch kits come with SFI Steel Billet Flywheel, Clutch Disc, Pressure Plate, Clutch Alignment Tool, Pilot Bearing, Throw-Out Bearing...!!!
Level 1 425hp/tq $699
Level 2 525hp/tq $699
Level 3 700hp/tq $729
Level 4 775hp/tq $729
Level 5 825hp/tq $929
Level 6 900hp/tq $929
Steel Billet Lightweight Flywheel 18lbs $50 extra
Freight Cost on All Monster Clutch Packages $49.95 in lower 48 states
A&A Corvette SuperCharger Kits
A&A Corvette Supercharger Kit 97-04 Base Price $4995...
Installed Price Turn Key Deal w/Custom Dyno Tune $6499.!!WOW Dont get left behind.!!
•8 Rib upgrade $995.00
•V-2 T Trim $199 upgrade
•V-3 SI Trim $199 upgrade
•V-3 T Trim $299 upgrade
•V-7 JT Trim $699 upgrade
•V-7 YSI Trim $799 upgrade
A&A Corvette Supercharger Kit 05-08 Base Price $4995...
Installed Priced Turn Key Deal w/Custom Dyno Tune $6695.!! WOW get BLOWN..
**Corvettes 2009 & 2010** Also extra $100 Labor for 2009-10 Corvettes...
•Z06 & LS3 kits add($749)
•8 Rib Upgrade $995.00
•V-2 T Trim $199 Upgrade
•V-3 SI Trim $199 Upgrade
•V-3 T Trim $299 Upgrade
•V-7 JT Trim $699 Upgrade
•V-7 YSI Trim $799 Upgrade
A&A C5 Supercharger Kits $4995
A&A C6 Supercharger Kits $4995
We accept Visa, MC, Disc, Amex, Paypal, Cashiers Check..!!!
Old 05-11-2010, 11:25 PM
2000BSME
2000BSME's Avatar
need a set of Russel brake lines (actually just one to replace rub damage). Where is the link on your post mang!!!????
-nevermind.. I see that you don't have online ordering yet...
I'm working 3rds this week.. .what hours can I call you? I'll be asleep most the day, so early or late will be great! Let me know please.
#692190 ALL C5's & Z's 97-04 $99.99
Old 05-12-2010, 08:52 AM
Former Vendor
Hi, we are here from 9am-9pm Mon-Fri and 10am-6pm Sat-Sun, Eastern Standard Time...LMK..we will be glad to help you...thanks Mike Yeager 1-864-404-1776...
Old 09-27-2010, 06:12 PM
Former Vendor
To Eastcoast Performance Has You Covered>>>Supercharger Kits/Axles/Clutches/Couplers!!!
Quick Reply: Eastcoast Performance Has You Covered>>>Supercharger Kits/Axles/Clutches/Couplers!!!
