1st impressions of the A6s on the circuit
Before I start, let me say that I am aware that A6s are the Autocross tire and Hoosier states that they operate best around 150deg F
For 2 seasons I was using MPSCs, so this was new direction for me.
I did 3 track events on these. 2 events 65km, 1 event 230km and half an event of 25km so thats 385km and add to that 175km of easy driving to and from the events to give a total life of 560km
Pit temperatures were taken after every session and they were consistenty aroud 185F, so I suspect that under race conditions they were around 200F. Air temps were typically 90F, o track a shade more I suspect.
On the 1st event (65km of twisty circuit) they were 3 secs a lap faster than the Michelins, On the 2nd event (230km of a much faster circuit) they were 2 secs slower, on the 3rd event (the 65km twisty) they had dropped to 2 secs faster than the Michelins and by the 4th event they were shot and pulled the rubber off the carcus after a few laps.
I got about 4 times the use of the Michelins (more than 2,000kms), but the Michelins never got hotter than 170
So I have ordered a set of R6s and I will try again. I can see the A6s as great for finals only and in cool weather.
I will report back on the Rs in 3 weeks time after I do a similar set of events
John
John
I've run Hoosier R's and GY slicks, never MPSC's though. I'm guessing they cost more when you consider how many deals you can find on this forum for the GY and Hoosier slicks. I think I've paid $500 for a set of unused GY slicks before, give or take.
John
John
It is an incorrect urban myth that Hoosier A tires don't operate well at 200 degrees. They will work better than R tires under all conditions. Used A tires are faster than new R tires. They don't last as long, but R tires start out bad by comparison and then heat cycle out even faster and worse than A tires.
I can't stand R tires by the third heat cycle, not that I like them much new. I would rather run A's down to where the grooves are almost gone than a three heat cycle R.
Hoosier A's work as good as any other tire I have raced on even when the it is a 100 degree day.
Oli
Oli
i
i
Not true. They last every bit as good as the Rs. You can over-drive both like any tire. The A is just as resilient as the R. I am disappointed with the R. It is not anywhere near the versatile tire the A is unless you call rock hard useless after the third cycle a good attribute.
The A has two distinct advantages:
Oli
- It is faster right out of the gate at the beginning of the race
- It is faster from the beginning all the way to the end, even 40 minutes into the race
Oli
Oli
Oli
Being a veteran of single-tire series' and from a generation where Hoosier's autocross tire really would not survive track duty, I find this discussion interesting.
Do the R's not have ANY advantages.........ie longer life, more consistency (be it slower?). If they are so bad, why don't they just stop making them??
I've been running 4 year old used GAC tires and put them to good use, but hopefully I'll try a set of fresh tires again one of these days!
The R can disappear and I would never miss it. I am not sure what it is useful for except if you want to use it for twice as many track days as an A. Physically the carcass will last twice as long, but its useful life is a mediocre performance in three heat cycles.
Looks like I am/will be the test case then as I am going to do both A's and R's back to back. Although as the air temps increase the R's may be at a slight disadvantage.
My 65km events consist of the following:-
2.55km lap
12 laps practice followed by 12 laps practice followed by 2 x 2lap time trial.
Start pressures 33/33 and hot 41/41
My 230 km session is a track day:-
5.1km lap
9 laps x 5 times = 45 laps
Start 30/30 finish again at 41/41
All my corvette competition is using R's so I thought I would have an advantage with the A's. We'll see
It appears for the 5.1km fast track (more straights and sweepers) that the MPSCs are the best bet and they last considerably longer although cost about twice as much
John
2.55km lap
5.1km lap
John
You will have a lap time advantage of a second per mile of track I predict.
Don't go by the Hoosier tire pressures. In my opinion they are all too high in their recommendations. I am trying higher pressures after talking with Hoosier at my last race, but I am not sold on it.
Oli
Oli
2.55km lap
5.1km lap
John
2.55km lap
5.1km lap
John
41 hot is way too high. I start with 23 cold. You have to go hard the first lap and get them up to temp which takes a quick hand but it's well worth it. Give it a try.
Mike
John, why don't you try either Goodyear or Hoosier SLICKS? Does your sanctioning organization require Dot R tires? I would call both Hoosier and Goodyear and discuss specifics of your track and temperatures needs and go witht their recommendations. Race tires are made for EACH track, let alone time zone and temperature. Work the phones, the reps will help you find hat you need.
This is absolutely 100% true. It didn't bother me at the time, because I just chalked it up to "you gotta pay to play". Now the more I look at the corded tires in my garage, the more I think "look at how much rubber is still useable on those tires" and it makes me sick.
The tires as a whole are not shot, but the inside on the fronts is. I run -3deg at the front with 4min total toe out. On the MPSCs i used 2.5deg and 4min and they also ripped the rubber on the inside front edges. The rest of the tire is only half worn
The rears are evenly worn to about 50% but they dont have the grip they did on that first outing.
Slicks are permitted but I dont really want to go that far just yet.
Too true
I've since corrected the toe, and I just rotate my tires much more often now, but I'll probably add more camber before my next event.
