Hoosier R6/A6 - 315's on stock fronts?
Old 05-11-2010, 05:43 PM
AtomicZ
AtomicZ's Avatar
Default Hoosier R6/A6 - 315's on stock fronts?
I'm curious if anyone is running Hoosier R6/A6 in 315/30ZR18 on the front of a C6 Z06 on factory rims. I know they have 295/30ZR18 and can use them if not able to go with the 315's.
I plan on running them at the track aggressively and want to make sure I don't have any issues. I can run 315's on my set of Forgelines on the front with no issues but that is on a wider rim.
Does anyone know of someone running 315's in the front that also has after-market brake duct hoses?? Any issues??
Old 05-11-2010, 05:48 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
10 1/2" rim? Same as C5Z rear? I've fit them on before.
Old 05-11-2010, 06:34 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I have a couple of scrubs in that size. You can mount them, use them, or whatever you would like.
Randy
Old 05-11-2010, 07:32 PM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
Nope, the stock C6Z fronts are 9.5". Hoosier recommends a wheel width +/- .5" in comparison to the affective tread width (315mm = 12.4"). With a 315, I wouldn't go any smaller than a 10.5" wheel; I'm running the 315 on an 11" front wheel.
Old 05-11-2010, 08:42 PM
dvandentop
dvandentop's Avatar
Eric my friend runs 315 all the time on the front of his z06 no issues
but he is using ccw 18x11 rims
you coming to track attack at all?
one guy has his spot for sale for $800 i think
Old 05-11-2010, 08:50 PM
drivinhard
drivinhard's Avatar
yeah that's a lot of tire for a 9.5" wheel.
275 ho-ho fits about perfect on a 9.5" wheel
Old 05-11-2010, 11:17 PM
AtomicZ
AtomicZ's Avatar
Randy
Randy - I'll be up tomorrow or Thursday to get my car. We can talk then.
That is kind of what I was thinking.
I run 315's up front on 18X11 rims and have had no issues. I picked up a set of OEM comp greys and was going to use them to keep an extra set of track tires on hand and wanted to run a 315 up front. Doesn't look like it will work very well - I'll just have to run 295's on the front with the stock rims.
Still not sure on Track Attack.
Old 05-12-2010, 08:48 AM
Pumba
Pumba's Avatar
The following rim widths are the general guidlines that OEMs use for tire sizes:
Tire ---Rim
275 = 9.5"
285 = 10.0"
295 = 10.5"
305 = 11.0"
315 = 11.5"
325 = 12.0"
335 = 12.5"
345 = 13.0"
Old 05-12-2010, 09:11 AM
thehammer69
thehammer69's Avatar
I run 315 Hoosier A6's mounted on OEM rear C5Z wheels on the front of my C5Z without any issues.
Old 05-12-2010, 02:31 PM
Zenak
Terminal Vette Addict
Zenak's Avatar
after you cross 275 you will get bad inner wheel rub on wheel lock if you have brake ducts in the front. FYI. make sure you get advice form people running ducts on wheel set up prior to making this decision.
Old 05-12-2010, 03:14 PM
AtomicZ
AtomicZ's Avatar
Good point.
Old 05-13-2010, 12:00 PM
shifter77
shifter77's Avatar
Use stock sizes and keep an eye on tire pressures.
Old 05-13-2010, 12:06 PM
Pylons
Pylons's Avatar
I autox on 315's up front on the base C6 18x8.5 wheels.
no extra brake ducting here though
To Hoosier R6/A6 - 315's on stock fronts?
Quick Reply: Hoosier R6/A6 - 315's on stock fronts?
