255/35/18 Hoosier A6 on 18x10.5 Wheel
I was thinking of trying this tire, its shorter but as wide as a 275. Any thoughts on if this would work on factory 18x10.5 Z06 wheels.
Thanks,
John
Thanks,
John
A few questions.
#1 - Why? I always thought more was better, especially in the way of tires. We are in a traction struggle with 315's...
#2 - a 255 is as wide as a 275? I don't think I've ever actually looked at a 255's measurements, but they should be about an inch narrower than a 275...
the "special" 255 hoosier has the same 10.3" tread width as the 275/17 and 275/18.
The 275/18 Hoosiers fit fine on a 10.5". A vertical slightly pinched in sidewall works better than one that's bulging anyway.
In our world because of class/mod/tire points, we are limited to smaller sizes. Maybe not ideal, but in reality, we have gotten our cars set up to work well on 275 C91s and A6s. You will find most of our lap times +/- what a 315 shod T1 C5 will run.
I was wondering about the tire staying on that wide a wheel with the small sidewall. I'd rather not run smaller tires and next year I'll probably move up a class then can run whatever I want.
John
Just an FYI, from the people I know that have run the 255, it needs a lot of camber, more than the norm for a Hoosier. A lot of RX-8 and Solstice drivers tried them, and they corded on the edge very quickly - on cars with -1.5 or more. All of these guys went back to the 245 or 285.
John
Damn, I'll have to look at that IIRC TTB (where my car starts) is a 245, so I have to take points for width and tire type, being able to run a 255 on an 18x10.5 or 17x9.5 and keep the 25.5 diameter - hmmmm its an idea.
So who is going to try it first - Mark, cheetah, jason??????
I would want the A6's over the R6's but it is a shorter tire.
John
John
Has anyone called Hoosier about this?
What would be the possible problems with a 10.5" wheel?
It would make wheel selection so much easier, and that 10.8" section (vs tread) width would get stretched to ~11.3".
Is anyone concerned about the load rating of the 18" 255s (1047lbs)?
Thanks,
John
Personally I think the whole "wider is better" thing is probably over-rated a bit. Actual size/shape of contact patch based on tire width, wheel width, is a good study. In our case, a sticky ~10" tire on a 3120 lb car is enough. I don't think any of my lateral G or braking numbers from the traqmate are really sucking hind tit.
At the end of the day, a properly matched wheel and tire size is more important than just cramming a bit 'ole fat tire on the x size rim. Anything more is diminishing returns IMHO.
Maybe at the end of the year if I got some extra Hoosier coupons to blow, we'll do a 275/315 speed test if Jeff will allow me to run a session or 2 in TTS heck I'd like to try 245/255-17's on some 9.5" rims, I think they'd be faster than most folks think.
Really, If you have run both 275 and 315 what kind of things different are done with the set-up? I would not know any better and just run the same set-up on both. In T1 we are mostly running 295's and 315's
John
The C5 T1 rules look really interesting this year, I would love to run one
