Front & rear glass removal for roll cage??
Hey Guys--
Can someone in the know tell me if front and rear glass removal is necessary for installation of a roll cage in a C5 FRC/Z06? I prepped/stripped my car to the installer's instructions, and he never mentioned anything about the front/rear glass. Now he's saying it's gotta come out, and I am less than thrilled to be hearing this after the job has already started. So, can someone tell me whether or not this is necessary?
Thx,
Fred
Thx,
Fred
Hey Guys--
Thx,
Fred
Thx,
Fred
(Don't ask how I know...)
not necessarily, but if you trust your guy to do the cage, then I'd trust is need for access. btw, they will almost certainly brake the glass in the process.
Terminal Vette Addict
Also depends a bit on the cage. I'd ask the company you bought it from.
Or post on the specific cage brand for other owners for installation advice :-)
Never reinvent the wheel!
My cage builder just installed the front portion of my custom fab cage and did not remove the windshield. He did pull out the fuel tanks to correctly weld the main hoop to the frame though.
And yes, this cage is being custom-built, not pre-built. I feel like this builder (who has done other C5s) ought to have mentioned glass removal previously, or find a way to adjust things *slightly* so that glass removal isn't necessary...not just spring it on me in the middle of the project.
Location: If you don't weigh in you don't wrestle Road America
I'm not sure why you'd remove the rear glass unless you are thinking about putting in lexan. If the cage builder wants access just pull the hardtop. It takes a little time and patience but I took a small reciprocating saw and ground the blade down so it was more knifelike and used a lot of silicone spray. I also used a floor jack and a 4x4 to help push it out. Like I said it takes some time but that way he doesn't have to work around the top.
The windshield is also removed with the saw (I used a sawzall with a knifelike blade and silicone spray).
Joel
Joel
