Reuse ARP studs on new bearings?
Old 05-21-2010, 10:31 AM
aspeters
aspeters's Avatar
Default Reuse ARP studs on new bearings?
I'm replacing front hubs on my C4 track car. Just installed ARP longer studs 2 months ago on the old hubs.
My mechanic seems to think that when the studs are tapped/installed on the hubs, there's a unique fit that occurs, and the studs may not work if tapped out and reinstalled in another hub.
Maybe with softer bolts this is possible; but with the hardened ARP studs is this an issue? Especially with almost new studs?
Old 05-21-2010, 10:45 AM
AlwaysInBoost
AlwaysInBoost's Avatar
I've pressed out OEM studs and reused them on new hubs without issue. I don't think you'll have a problem reusing ARP's.
Old 05-21-2010, 12:01 PM
ZR1 MK
ZR1 MK's Avatar
You can reuse them many times, but proper install and remove is a press fit, not a hammer.
Old 05-21-2010, 12:04 PM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I use a press to get mine in and out.
Old 05-21-2010, 12:30 PM
ryan0
ryan0's Avatar
yes
Old 05-21-2010, 01:06 PM
Zenak
Terminal Vette Addict
Support Corvetteforum!
Zenak's Avatar
as long as the stud looks fine, no cracks, no cross threads they are built to last forever (almost)
Old 05-24-2010, 10:07 AM
aspeters
aspeters's Avatar
Thanks all for the tips...I'll make sure he's using a press and not a BFH.
To Reuse ARP studs on new bearings?
Quick Reply: Reuse ARP studs on new bearings?
