wheel size question
Not sure on the 275 for 8.5 but I know you can do the 295 on the 9.5. Just look at all the C5Z's running Super Stock at SCCA Nationals and you will see mostly 295 Hoosier A6's on OEM 17x9.5 front wheels.
The T1 guys run (or used to at least) 315s on 11" rears and 10" fronts. Even so, you would likely be better served running appropriate rubber for your wheels.
Worse case, you will pull in the sidewalls causing the tire shoulders to roll a bit.
Depends on the tire brand, the section size (30, 35, or 40) and the diameter...
The Solstice guys are running 285 Hoosiers on 8.5 inch rims and it seems to work fine.
tirerack.com has all the specs listed for different brands. If you have a tire and rim in hand I would feel good bumping one size in general. Aspect ratio plays a part as stated above.
