Brake fluid / clutch fluid
Old 05-26-2010, 12:59 PM
TGiuliante
TGiuliante's Avatar
Default Brake fluid / clutch fluid
I am planning to flush my brake fluid and clutch fluid. I run approximately 20 HPDE events per year - what fluid(s) do you guys recommend?
Old 05-26-2010, 01:28 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Castrol synthetic in anything other than all-out-racing applications........... then AP600 is my fluid of choice I'm sure the AP660 is good, but I've never tried it.
Old 05-26-2010, 01:44 PM
sperkins
sperkins's Avatar
I swap between ATE super blue and amber.
Old 05-27-2010, 09:13 AM
J Ritt
J Ritt's Avatar
We are a forum vendor and sell AP Racing fluids. I'd recommend the AP Racing Super 600. It is currently one of the most popular fluids in professional motorsports, it's competitively priced, it's on the shelf and ready to ship, and it's DOT compliant.
Old 05-27-2010, 09:26 AM
beerkat
beerkat's Avatar
I still doing DE and I am not all that fast. I use Valvoline synthetic brake fluid and flush it before each weekend. Use in the clutch also. It has a fairly high dry boiling point and since I change it regularly I do not worry much about wet boiling point.
Old 05-27-2010, 09:33 AM
JRitt@essex
Supporting Vendor
JRitt@essex's Avatar
Trying my other, 'official' essex user profile.
Old 05-27-2010, 11:05 AM
davidfarmer
I'm with JRitt, AP is great, and a fraction of the cost of SRF.
Old 05-27-2010, 11:33 AM
BEZ06
BEZ06's Avatar
Here's a good StopTech article with general info on fluids and down at the bottom a list of a few different fluids and their boiling points.
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
Bob
Old 05-27-2010, 12:47 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
SRF the best by far. and if your doing 20 days the cost of fluid is squat.
Old 06-26-2010, 02:36 PM
Like dem Vettes
Like dem Vettes's Avatar
I use BG Super DOT 4 for brake and clutch. It's hard to find, though.
Old 06-26-2010, 02:46 PM
davidfarmer
My problem with SRF is that if your calipers are getting hot enough to NEED it, then you really need to address your cooling system. A healthy brake system should last several weekends with any good fluid
Old 06-26-2010, 05:50 PM
John Shiels
but some never will adress cooling so it is better to have SRF and not find out after you need it. Even if you have cooling ducts it still is useful as my rotors will glow in the daylight. Granted I could buy a 15" rotor and race calipers but then I need all new wheels and the price tag is crazy.
Old 07-03-2010, 12:46 AM
rustyguns
rustyguns's Avatar
naw!!!!!!!! it means your hauling *** and braking LAAAATE!
Old 07-03-2010, 09:44 AM
ace996
ace996's Avatar
Yep....even with cooling, I'd rather run the SRF and have the highest wet boiloing point in the business. After needing to bleed/flush fluid because of breakdown/moisture, doing little bleeds is cheaper in the long run with SRF.
I see it as 'safer', too, and that makes me feel better...
Old 07-03-2010, 02:43 PM
gkmccready
gkmccready's Avatar
I guess I'm the oddball. I like Motul RBF600.
Old 07-03-2010, 03:19 PM
rustyguns
rustyguns's Avatar
check the WET boiling point of motul vs SRF itsssssssss HUGE!
Old 07-03-2010, 04:06 PM
gkmccready
gkmccready's Avatar
Matches the price difference! As everybody else has pointed out, I bleed them so frequently that wet isn't really an issue...
To Brake fluid / clutch fluid
Old 07-03-2010, 05:59 PM
ace996
ace996's Avatar
That's the point of SRF...you don't need to push out so much when you do bleed. At the end of a season, most have spent less on the SRF than with Motul (what I used to use). And bleeding is not needed as often.
Eh...it's what one likes to do...change often with a cheaper fluid or keep a costlier fluid for longer. I like the SRF because I've never boiled it, even when I was less than attentive with bleeding.
Old 07-03-2010, 08:43 PM
dfinke23
dfinke23's Avatar
I saved money switching to SRF.
Old 07-04-2010, 01:54 AM
rustyguns
rustyguns's Avatar
me too
Quick Reply: Brake fluid / clutch fluid
