Quick Question Regarding Caster
Old 05-27-2010, 11:57 AM
dan_t
dan_t's Avatar
Default Quick Question Regarding Caster
Please can someone tell me the effect of steering feel by caster change?
Ie does LOTS of caster make steering feel heavier or light? stable or twitchy?
I think adding caster will make the steering heavier and duller? Which is what I'm after.
Old 05-27-2010, 01:49 PM
geerookie
geerookie's Avatar
Adding caster will make the steering want to self center. This can feel heavier. It also aids in turn in and makes the steering more stable at higher speeds without adding toe in.
I run about +8.7 degrees of caster.
Old 05-27-2010, 01:54 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
"heavier" and "duller" are not words I necessarily use, but more castor will increase the steering effort, and increase straight line stability. It will make the car want to self-center, so it will be less "twitchy" going straight, but possibly more "twitchy" in the turns.
It also increases the amount of camber gain you get on the outside tire when you turn, so more castor gives more camber in the turns
Old 05-27-2010, 03:13 PM
Painrace
Painrace's Avatar
Try going to 0.060" toe out! We all have different driving "feels"!
Jim
Old 05-28-2010, 01:14 PM
dan_t
dan_t's Avatar
I managed to get 6deg caster on both sides and the steering feels much better now. Thanks for everyones input on here.
To Quick Question Regarding Caster
Quick Reply: Quick Question Regarding Caster
