Best Air Pressure for the track?
Old 05-28-2010, 11:59 AM
schnellTTZ06
schnellTTZ06's Avatar
Default Best Air Pressure for the track?
My friend and I both have the Nitto Nt-01 tires - 275s front and 315 rear on stock C5Z06 sized wheels. We were running at the Nürburgring which is quite long and the tires heat up pretty good. I thought a lower pressure would be better but the tires just squealed like crazy and didnt stick well at all. Just curious what pressure works best for this situation?
Thanks,
Old 05-28-2010, 12:02 PM
thehammer69
thehammer69's Avatar
Thanks,
I'm gonna GUESS that about 36-38 psi HOT air pressure.
Old 05-31-2010, 12:08 PM
shifter77
shifter77's Avatar
start with 35 psi cold to start.
Old 05-31-2010, 12:56 PM
johninar
johninar's Avatar
I also run the NT01, and start at 35 cold and I keep them at 38 hot. This is on a relatively short(slow) 1.8 mile, 10 turn course. I've seen them hit 45 and the grip really goes away at that pressure.
Old 05-31-2010, 03:10 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
275f and 315r is going to be a pushy bitch.
Old 05-31-2010, 03:22 PM
gkmccready
gkmccready's Avatar
World Challenge is forced to run 275f 335r and they manage to make it work somehow. :-)
Old 05-31-2010, 05:32 PM
Z06trackman
Z06trackman's Avatar
If you buy a probe type tire temp gauge you will be able to answer this yourself for any car, tire, track or weather. Take readings on the inner tread block, the center, and the outer tread block. If the center of the tire is the lowest temp, then you need more air. If the center is the hottest, then you need less air. You want even temps across the tire for max wear, and 10 - 20 degrees hotter on the inside (with middle in the middle) for max grip (typically - you can always experiment). This also provides ideal data to help sort your chamber settings.
Only check one axle at a time because they cool off real quickly (unless you have a crew to do this for you).
Good luck.
Old 05-31-2010, 08:19 PM
brkntrxn
brkntrxn's Avatar
On my C5Z06, I run NT01 275 fronts and 315 rears. I start with 27-28 cold and look for 36-38 hot.
I drive the car pretty hard, so my tires tend to heat up a bit.
-Kevin
To Best Air Pressure for the track?
Quick Reply: Best Air Pressure for the track?
