CCW Wheels: Difference between Race and Street Version?
I'm looking at a set of CCW classics and what is the difference between the street and race version with the street version being more expensive?
Street version
Track version
Street version is NOT drilled for lightness, has center caps. cadnium bolts
track version drilled for lightness, no center caps and has steel inserts for stud holes, grade 8 bolts
My street version have steel inserts in the stud holes.
IIRC track versions drilling for lightness is an option now as well as shot pean and anodizing
Track version
Street version
Track version
Track version
Race version will not accept the center cap. The center cap is almost 1 pound by itself
The stud holes and holes drilled for lightness between the stud holes are not interchangeable.
Only the stud holes have the steel sleeve.
Your '68 has a cap on the hub to keep the grease clean and inside the hub bearing, right? Can't you put a chrome cap on in place of the black painted one - same shape, different color?
I Ordered a set of Race Classics this week. John told me the price difference between the two is basically from the ARP fasteners that the street version use because they cost more.
Also, street versions are now getting a slightly thicker Aluminum barrel. This is a recent change. This will increase weight on those wheels.
That is also why I like the black. Clean them off and look for small cracks.
Any race wheel does have a finite life time.
Next set most likley will be the C2K as these will fit over a BBK set up.
http://www.ccwheel.com/files/wheelpr...lay.php?id=C2K
Yeah it be for the '68, looking at getting more involved in road racing/events at Texas Motor speedway. The ralleys while look good are my really only drawback as well as modern rubber. Figured I can can kill two birds with one stone.
Difference is the fasteners.
I agree with AU N EGL... if you use aluminum or any other fatigue limited metal, it will fail given enough cycles (thermal and load). Some designs last longer than others though.
ElisTwoCents (06-06-2021)
Oh I agree that aluminum will fatigue eventually, but I've only seen one company make wheels that crack after 6 events...........
Would you expect OEM aluminum wheels to crack in a season?
If you can or do use a spacer, CCW can machine a spacer with a center cap as an integral part to fit whatever the opening is. Even a thin spacer would provide the opportunity to have a center cap, if that is what you want.
