New Corvette owner wants to go to HPDEs!
A few weeks ago I posted q's about what Corvette to get for 10 per year HPDEs and overall daily driver. I want to keep it stock for durability....
So last weekend, I got 2006 C6 Corvette with Z51 and 3LT packages with only 8,5K miles on it!
Few q's about track usage:
- what brake fluid for track (I used Motul 600 for Audi);
- what clutch fluid to use (can I use Motul 600)?
- what coolant to use? I hear mixed reviews about DexCool...
- what engine oil to use for track? (Stick with Mobil?)
- what tranny/diff fluid to use? (I used SWEPCO in Audi/Porsche with good results)
Thank you!
Thank you!
Thank you!
Thank you!
Location: If you don't weigh in you don't wrestle Road America
Yep Motul will work fine as clutch fluid (brake/clutch fluid both systems are hydraulic). I use SRF, expensive but you never have a problem with it.
Engine oil is kind of up to you. Mobil 1 works well, some people perfer Amsoil or Redline.
Tranny and Diff fluid I would say any premium synthetic, I use Royal Purple. Others like Redline, RPM Transmissions and DTE both say either or. Truthfully its easier for me to get Royal Purple so that's why I use it.
Dexcool with Water Wetter will work fine.
with all the above replies, but I would add one comment.
Go with a slightly higher Viscosity oil for a track car. On the track, your engine is going to get warmer than the average daily driver. A higher viscosity will work a little better at those higher temperatures. I'm still talking about Mobil 1, but 15W-50 instead of the recommended 10W-30.
Folks also add an extra quart or half quart of oil on track days.
I was planning to use 10w-40, however it's NOT dedicated track car - it's also my daily driver.
Should I also overfill by 1qt the LS2 engine, like LS6 owners do?
Yes. Mine is an LS2, and I overfill by one quart at the track. The high G left turns slosh the oil to the side of the oil pan away from the oil pump pickup. Adding an extra quart combats this. By the way, you will also find that your car burns about a quart of oil during a track day. That's another reason to overfill, so it doesn't get low a quart.
When you mentioned consume oil - did you mean normal oil consumption or
abnormal, like due to blow by, etc.
1Qt per track day seems a lot for new engine like LS2.
I see a lot of guys with Porsche 944 add 0.5qt after every heat session, but those are older engines....
for coolant, i switched to water+water wetter (mostly for safety reasons) but it looks like I got ~5-7 degree avg temp drop out of the deal.
if you park outside and daily drive during a winter, probably not the best idea though.
It's "normal" or at least to be expected (blow-by) even in the newer engines. I watched a guy with a C6Z dump his catch-can several times during the day.
What about rims for track?
Will C5 Corvette rims fit/clear C6 Z51?
If not what is the good wheel setup for track - not many brands carry R-comp 19"inch.
Terminal Vette Addict
Keep it simple. Look for all your rookie questions in here:
http://forums.corvetteforum.com/auto...e-learned.html
its a sticky for this Forum. If you can't find it there, then ask. About 99% of questions are answered there.
