Brake Caiper Seals, Where can I buy some?
Old 06-07-2010, 05:47 PM
Maxx Schlick
Maxx Schlick's Avatar
Default Brake Caiper Seals, Where can I buy some?
I want to rebuild my Brake Calipers using the DRM stainless steel pistons. I need a new set of piston seals. GM only sells it as a kit that includes Pistons, Seals and Dust boots. $90 per caliper.
All I need is the rubber seals. Where can they be found?
Old 06-07-2010, 06:03 PM
Last C5
Last C5's Avatar
Almost any auto parts store has caliper rebuild kits.
Old 06-07-2010, 08:02 PM
Zenak
Terminal Vette Addict
Support Corvetteforum!
Zenak's Avatar
I just got my Kit with my DRM setup. ASK them it was like $39 per caliper i think?
You can also try gmpartshouse.com which gets anything GM pretty cheap
you cant get it except as a kit I think.
You arent doing the dust boots at the same time?
OEM calipers dont like dust. Esp after your pad is 50% or more gone
Old 06-07-2010, 08:21 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I would buy OEM seals, it is a kit so you will get the boots also. Boots will burn off fast so I would keep then if you sell the car or use them in the winter.
Old 06-07-2010, 08:22 PM
gkmccready
gkmccready's Avatar
They're available at the URL Randy@DRM posted in your other thread with the SS pistons, no?
Old 06-07-2010, 08:55 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
He has a C6Z. The only ones that are around now are from GM @ huge prices. They come with new pistons if that tells you anything....
Randy
Old 06-07-2010, 09:30 PM
Cyclonite
Cyclonite's Avatar
Nope. Not for the c4/5 at least. The only caliper parts kits I've found have the rubber boots that go on the caliper pins, and the clips for the pads. No seal kits, no caliper boots...
Napa, autozone, pepboys, advance auto, all nada
Old 06-08-2010, 03:35 AM
Last C5
Last C5's Avatar
Centric Front Brake Caliper Repair Kit
Part Number: CE143.62036Manufacturer Number: 143.62036
Old 06-08-2010, 09:29 AM
Cyclonite
Cyclonite's Avatar
Thanks, is this c4 or c5? I've got one of each (no, not on the same car )
I just bought some SS calipers from another forum member here, mainly because they came with boots/seals (also I knew I'd want to make this upgrade).
Old 06-08-2010, 12:45 PM
Last C5
Last C5's Avatar
That stock number is for the C5, sorry I'm so used to buying parts for my C5s I didn't even bother to look for the C4.
Old 06-09-2010, 04:09 PM
Cyclonite
Cyclonite's Avatar
Thank you, I'll have to pick up some more so I have some spares.
Old 06-11-2010, 03:38 PM
2000BSME
2000BSME's Avatar
Just take out your o-rings and find some viton o-ring stock to replace them with. If you can't find any at a hardware or autoparts store, get on McMaster Carr and order the size you need.
I'm lucky in that respect, we have drawers full of o-rings where I work. We go through them like water in the mill.
Old 06-11-2010, 04:08 PM
LS3x416
LS3x416's Avatar
I got them from Gene Culley and the Pistons from DRM.
Old 06-14-2010, 11:02 AM
avizer
avizer's Avatar
I am trying to find the dust seals for a 2010 GS and I am told that there are non anywhere. Who is Gene Culley, anyone can help?? Thanks. I have the car in the air waiting for the calipers to be rebuilt..
thanks,
Old 06-14-2010, 11:33 AM
rag1998
rag1998's Avatar
Click this link: http://forums.corvetteforum.com/memb...ne-culley.html
thehammer69
thehammer69's Avatar
GMpartshouse.com
Old 06-14-2010, 01:10 PM
avizer
avizer's Avatar
tried gmpartshouse... they dont have it..
To Brake Caiper Seals, Where can I buy some?
Old 06-14-2010, 01:43 PM
Zenak
Zenak's Avatar
thanks,
its the GS just using the Z06 caliper?
Old 06-14-2010, 03:43 PM
avizer
avizer's Avatar
Yes, GS is z06 Caliper.
Old 06-14-2010, 07:48 PM
Zenak
Zenak's Avatar
Exactly! If you asked the the 2010 GS caliper there may not be a rebuild kit for that. So ask instead for a 2008 Z06 caliper rebuild kit. See what happens!
Quick Reply: Brake Caiper Seals, Where can I buy some?
