What material is best for a track car frame?
St. Jude Donor '09-'10-'11
Some of the GM engineers are one of our events asked a few of us what we wanted in a track ( ready to prepar from the Factory) car?
Steel frame
LS2 or LS3 WITH DRY SUMP
Oil cooling, trans cooling
T1 suspension
ZR1 / GM Motor sports gear box / ratio
Bigger Brakes
Fender flairs for bigger tires.
and two years later the GS comes out real close.
actually the 6 Body in white cars that went to Europe to be built in to GT3 cars was closer
Steel frame
T1 suspension
Bigger Brakes
Thanks, just trying to understand what would work best and why.
Steel Frame is stronger and you can WELD a steel roll cage to it.
the Aluminum frame of the Z06 or ZR1 needs to have a special aluminum plate welded to the frame, then a special epoxy used to hold a steel plate to the aluminum plate, then a bolt hole must be drilled through the plates and the frame, ( Plate on each side of the frame ) and an aluminum tube put through the frame and plates. A special bolts are put through the plates and the frame and tightened up. Making sure no aluminum and steel touch each other.
Then for an 8 point cage, 16 plates need to put on the frame.
Now that all 16 plates arein place, a Steel roll cage can be fabricated and welded to the steel plates.
ie the cost of the a roll cage into an aluminum frame just doubled.
or something like this. ...
Next aluminum frames almost always can not be fixed if there is an accident. where steel frames can be straighten or pieces cut off and replaced.
Steel is also much stronger are resists the twisting stress of racing.
most ppl that race, semi pro to amateur, do not have the resources or money for high priced aluminum framed race cars.
Former Vendor
Just throwing that out there.
Randy
Au n egl in this quoted response to the question of things wanted in a track car, at the top of the list is “Steel frame”. Could you elaborate on this? For track cars, is a steel frame better? What about an aluminum frame like in the ZO6 or ZR1? Is mass an issue?
First off I would like to thank all of you that have posted. The primary reason I asked this question, with the current push for more fuel efficiency, mass becomes a bigger player. That said, in my opinion I would expect at some point, things like steel frames might be a thing of the past. I would expect lighter materials to become more common use.
Would there be a better way to provide roll protection if I no longer have materials that are easily welded?
I doubt you'll see mass production cars with aluminum frames because the cost to repair them will out weight the benefit, especially to insurance companies.
I could see the industry going to C5/C6 style car (i.e. steel frame and glued on lightweight panels).
The only other production car other than the C6 Z06 that used aluminum was the Accura NSX that I know of.
Obviously the exotic car manufactures use a combination of materials to make their cars, but I really don't count them as everyday cars.
Former Vendor
Ok, did a little digging in the Collision Repair Manual for ZO6/ZR1 repairs, they show using a pulsed-MIG (P-MIG) for welding the aluminum frame and using 5356 wire of .035" size with 100% argon shielding gas. Other than the need to supply pads to bolt a steel roll cage to, is there something else that makes repairs harder than steel frames?
