Corbeau seat swap question
Old 06-08-2010, 07:58 PM
cb63
cb63's Avatar
Default Corbeau seat swap question
I have a set of Corbeau A4 seats ordered for my 09. I have read about issues with the air bag not working with aftermarket seats. The car is the basic 1lt so I do not have telescoping steering wheel.
Does the Pfadt plug kit keep the airbag working
Thanks for your help
Old 06-08-2010, 09:03 PM
m3to335
m3to335's Avatar
I believe the Pfadt is just a means of making the light go out. The airbag depolyment is depending on a series of sensors working in sync.
Old 06-08-2010, 11:06 PM
drivinfast
drivinfast's Avatar
I have the harness kit from pfadt. you have to take the larger module off the stock seat and use it underneath the corbeau. it just turns off the airbag light and allows the telesope to work...
for your application without a telescope just get a black circle dot and cover the the airbag light instead.
To Corbeau seat swap question
Quick Reply: Corbeau seat swap question
