Jacking one side of the car w/ one jack????
Old 06-09-2010, 07:43 PM
froggy47
froggy47's Avatar
Default Jacking one side of the car w/ one jack????
I was reading another thread & a guy said he saw a radiator split open doing this.
I have been doing it for years c4 & c5 when I change from street/track/street wheels.
Usually the rear jacking puck location, but the front jacking puck location works also.
Usually it's 10 to 15 min a side as I whip off two wheels & put the replacements back on, set shocks, check brake pads rotors etc.
Am I nuts for doing this or is the car stiff enough that it's not a problem.
Obviously if it were going to be more than 10 to 15 minutes for some real work I would make other lifting arrangements.
Old 06-09-2010, 07:46 PM
wallyman424
wallyman424's Avatar
that is BS, no way you can split a radiator doing that. MAYBE on a car w/ a really flimsy chassis, but no way no how on a late model vette.
don't even give it a second thought.
Old 06-09-2010, 07:52 PM
Zenak
Terminal Vette Addict
Support Corvetteforum!
Zenak's Avatar
see jacking here:
http://forums.corvetteforum.com/auto...e-learned.html
Old 06-09-2010, 08:10 PM
GettReal
GettReal's Avatar
I jack up my car using a single jack right in the middle of the car with NO issues ever..
However, Its stiff enough that if I do just use the front or rear lifting spots that I only need a couple extra pumps of the jack to get the other wheel off the ground.
Old 06-09-2010, 08:25 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
Old 06-09-2010, 09:20 PM
Datawiz
Datawiz's Avatar
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Been jacking my '08 Z from the front jacking point for nearly 3 years with zero issues.
Old 06-09-2010, 09:33 PM
MAG STAR
MAG STAR's Avatar
Old 06-09-2010, 09:42 PM
varkwso
varkwso's Avatar
Jack away...it will be fine...
Old 06-09-2010, 09:56 PM
sleeper02Z06
sleeper02Z06's Avatar
Jeff,
I said that to Rhonda one day and woke up the next morning with a black eye and no memory of the last 8 hours!
Joe
Old 06-09-2010, 10:00 PM
wallyman424
Originally Posted by sleeper02Z06
Jeff,
Joe
Old 06-09-2010, 10:10 PM
longdaddy
longdaddy's Avatar
on the porsches, it is possible to get 3 wheels in the air at the same time with one jack
i bet you can get a lotus completely off the ground if you find the right point!
Old 06-09-2010, 10:17 PM
wallyman424
yeah but then the frame will bend and it'll be totalled.
Old 06-09-2010, 10:19 PM
varkwso
varkwso's Avatar
Jeff,
Joe
Joe
Thanks for the gut laugh. I needed it!
Jeff
Old 06-10-2010, 08:11 AM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
Joe
Jeff
Awwwh, you bunch of jack-offs!
Personally, I use two jacks from harbor freight. The 1 1/2 ton aluminum shorties work just fine on one side at a time for changing tires quickly. The frames really don't like concentrated load in small contact point for half the weight of the car unless you use a large plate to distribute the load.
Old 06-10-2010, 09:46 AM
wtknght1
wtknght1's Avatar
Jeff,
I said that to Rhonda one day and woke up the next morning with a black eye and no memory of the last 8 hours!Joe
Good one Joe. That's funny right there...I don't care who you are!
Jacking with a single jack is just fine. I use the spot where the large floor pan support spreads out and meets the frame (about mid point down the side). I normally try to put the jack head touching both the frame and the pan support.
Old 06-10-2010, 11:49 AM
davidfarmer
davidfarmer's Avatar
I agree with Chris, right where the front seat reinforcement is welded to the frame rail. Just be careful that your jack can roll, or the jack head can slip outward and damager your rocker panel.
Old 06-10-2010, 12:24 PM
SPDYC6
SPDYC6's Avatar
I always use the rear jacking and never had any issues. If you saw how the frame is made and put together, you wouldn't worry.
Joe
To Jacking one side of the car w/ one jack????
Old 06-10-2010, 12:31 PM
Joy of 6
Joy of 6's Avatar
The frame is a single piece hydroformed unit so you should be able to jack it up anywhere. I use the front puck on my car for both wheels
Old 06-10-2010, 01:58 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I didn't think the frame was formed in one entire piece?
Old 06-10-2010, 03:53 PM
beerkat
beerkat's Avatar
I use to jack my car from either of the puck location. Then I was shown that it could be lifted in the center of the car where Chris and David are talking about.
Quick Reply: Jacking one side of the car w/ one jack????
