Need Quick reply: adjusting front camber
Old 06-20-2010, 06:51 PM
thehammer69
thehammer69's Avatar
Default Need Quick reply: adjusting front camber
I'm about to adjust my front camber. Do I need to turn BOTH adjusters equal amounts on each side, or Can I do just one. If so, which one do i adjust, the forward one or the rearward one.
Just for reference....I had the alignment done previously by David Farmer. I'm just wanting to add some more camber with the bigger tires I just got and am not sure on the correct way. Right now I'm at around -2.2 and I know the caster is equal.
Old 06-20-2010, 06:52 PM
gkmccready
gkmccready's Avatar
If you turn just one you'll change caster...
Old 06-20-2010, 06:57 PM
thehammer69
That is actually why i thought to ask the question. I was about to do both, then my mind started wondering that if the forward one was the only one done that maybe it would INCREASE Castor. Of course i have no clue if that would be the case, but more caster would be good if I can accomplish this with just one adjuster.
Old 06-20-2010, 08:21 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
if you want to maintain castor, you should first check to see if there are any washers behind the upper control arms. If so, remove a single washer from each one to gain some neg camber. If you do the lowers, you need to move both the same amount measure at the centerline of the bolt, NOT the number of "ticks" on the bolt head.
Old 06-20-2010, 09:28 PM
thehammer69
i'm done for now...I really need new bushings...I guess the rubber ones take a beating.
To Need Quick reply: adjusting front camber
Quick Reply: Need Quick reply: adjusting front camber
