6'3" ?
Old 06-24-2010, 02:05 PM
Cloaked323
Support Corvetteforum!
Cloaked323's Avatar
Default 6'3" ?
I have a friend who wants a C6 vette so much so that he went to test drive the car. After the test drive, he stated that he wanted the car but only if the seat could be mounted back about about 4 inches. I thought that there was only about 3 inches avaliable. So how far back can you mount the seat safely? TIA
MW
Old 06-24-2010, 02:14 PM
SIK02SS
SIK02SS's Avatar
I'm 6'3 180lbs, and in my C5 I have plenty of leg room; head/helmet room is very close, but leg room I'm good on. That's with a cage and everything. I wonder what the difference would be between the C5/6 in that respect? It's been so long since I've even sat in a C6..can't remember
Old 06-24-2010, 02:29 PM
dub squared
dub squared's Avatar
I'm 6'3" 290 lbs and I am very confortable in my 05 convertible (top up or down).
Old 06-24-2010, 02:33 PM
davidfarmer
davidfarmer's Avatar
The C6 is much more cramped than the C5, both the underside of the dash, and the head room (at least in the C6Z06).
This is what we did in our C6Z06....my co-driver is about your friends height.
1. we remove the center bolster. Required removing the seat once, to disconnect the seat heater connection, then you just unclip the center section when at the track. Allows the side bolster to give more support also.
2. removed the headliner. This might be Z06 only, but it "swoops" down several inches, right over the drivers' head, and removing it gives extra head room. Since ours is 90% track car, aesthetics don't matter.
The OEM seat is pretty much against the rear bulkhead when all the way back, so relocating isn't really an option. You could go to an aluminum, fixed seat, but this isn't very practical for a street car.
Old 06-24-2010, 02:36 PM
Aardwolf
Aardwolf's Avatar
I'm 6'3" and I rode in an instructors C6. With my helmet on I could not sit fully straight. I needed about 1/2" of extra room by my estimation. I really liked the car but having my head tipped sideways wasn't fun.
Old 06-24-2010, 03:47 PM
Armycop
Armycop's Avatar
At an honest 6'4", I don't fit comfortably in a C6; nevermind with a helmet! In my C5 however, I find plenty of room. Go figure.
Old 06-24-2010, 04:18 PM
Leafless
Leafless's Avatar
6'2"
Leg room- I want more.
Head room- I can wear a cowboy hat with the top on.
Old 06-24-2010, 04:49 PM
Dirty Howie
Dirty Howie's Avatar
MW
He needs a bubble roof like Tom B
DH
Old 06-24-2010, 04:51 PM
2000BSME
2000BSME's Avatar
wow. I didn't know there was less room in a c6. I'm 6'8" and have enough room to sit straight in my c5.
Old 06-24-2010, 04:57 PM
2000BSME
2000BSME's Avatar
Old 06-24-2010, 05:06 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
I'm 6'3" and fit in my C4 fine with helmet and all. Crazyness. I've driven a couple of C6's with no issues, but not with a helmet. Come to think of it, they were both verts.
Old 06-24-2010, 05:21 PM
davidfarmer
they keep making the interior curvier and squisher...........yet the exterior is sharper and edgier! You can quote me if you'd like!
Old 06-24-2010, 06:24 PM
Cloaked323
Cloaked323's Avatar
Leg room is the issue for him so he wants move the seat back has anyone had this done or relocated the seat DIY
Old 06-24-2010, 08:29 PM
davidfarmer
like I said, the seat is already against the bulkhead, so there is nowhere to move it. Removing the center bolster gives you and extra inch or so, as your rear can sit deeper into the seatback.
Old 06-24-2010, 09:13 PM
Cloaked323
Cloaked323's Avatar
Okay thanks for the info I will pass it on
Old 06-24-2010, 09:53 PM
Timz06
Timz06's Avatar
And I thought people were only 6'3'' on the internet! Seriously, I have a colleague that is 6'4'' and his knees are all bowed up in the passenger seat of my 08 z06.
Old 06-25-2010, 09:59 AM
Zenak
Terminal Vette Addict
Zenak's Avatar
I recommend an after market low profile seat track if you want to use the OEM seats, BUT you will lose all your power options and will need a seat simulator plug to make the car think the power seat is still there. You will be fine without a helmet at 6'3 but honestly with teh helmet it would be rough. At 6'2 with a caravaggio on stock rails I need to remove all padding and still barely fit in my FRC with helmet
Old 06-25-2010, 02:20 PM
steponc
steponc's Avatar
St. Jude Donor '14
Default Room
I let a co-worker, 6'3", drive my 03 Z06 and his remarks are the same as everybody above. He also told me that his test drive in a C6 was cramped. In my auto X 03 Z06, I installed an 02 headliner that does not drop down at the back and gave me more room. I also switched the seat tracks so the manual track is on the driver side and cut the raised portion at the rear of the track and bolted it straight though the track.
Old 06-25-2010, 02:44 PM
CDN_Wolf_eh
CDN_Wolf_eh's Avatar
I'm 6'4" ... about 318 lbs ... hopefully will be sub 300 in another month!
plenty of head room in my '05 Vert with the top down ... and it's still fine with the top up!
my '07 Z06 is fine, except when I'm on the track with my helmet on ... had my roof liner removed, which bought me an inch ... and it's now livable on the track ... I find I slide the seat forward a bit for proper hand / arm placement, which also buys me a bit of headroom, due to the roof line.
Mark
To 6'3" ?
Quick Reply: 6'3" ?
