Z51 Sway Bar Question
Old 06-24-2010, 04:02 PM
Spdfrk81
Spdfrk81's Avatar
Default Z51 Sway Bar Question
I have an 08 1LT with the base suspension running RE-11's on all 4 corners. I am upgrading the brakes to the Z51 upgrade and was also looking at the Z51 sway bar. What advantage/disadvantage will i see with just changing the sway bar without any other suspension mods?
Also which brakes pads are most people using for a daily driver that autocrosses every other weekend with Z51 rotors?
Old 06-24-2010, 10:02 PM
avizandum
avizandum's Avatar
The Z51 bar will make the car stay "flatter" when cornering but will induce a bit more understeer. It will keep the car more settled in transitions and slaloms.
A guy I ran against last year (we were 1 and 2 in our class and I have Z51) had a base coupe with a Z51 front bar and Z06 shocks and it was a great setup on good street tires - he ran kumho XSs - I think the RE11s are faster.
I ran Carbotech 8s and 6s - good pad but very noisy and dusty. You should do fine with Z51 or Z06 pads.
Old 06-24-2010, 10:34 PM
WNeal
Support Corvetteforum!
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
I agree with above as the car may push just a bit. When I went from the Z-51 bar to a much bigger front bar, the car actually "skipped" a bit up front when making hard right handers.
Hoosiers solved that problem
To Z51 Sway Bar Question
Quick Reply: Z51 Sway Bar Question
