AP Racing Track Kit | C5 Z06 | Install/Pictures
Old 06-25-2010, 01:47 PM
0Ron@Vengeance Racing
Former Vendor
Ron@Vengeance Racing's Avatar
Default AP Racing Track Kit | C5 Z06 | Install/Pictures
Call for pricing.
Old 06-25-2010, 01:53 PM
Zenak
Terminal Vette Addict
Support Corvetteforum!
Zenak's Avatar
isn't that the quantum kit with heat guards?
what size wheel, offset etc? rotor size? which AP calipers?
Old 06-25-2010, 03:06 PM
Former Vendor
Yes, the brake cooling is the quantum kit.
Factory C5Z wheels.
Rotors are 355mm x 36mm.
AP calipers are p/n AP1600TR.
Old 06-25-2010, 03:18 PM
SIK02SS
SIK02SS's Avatar
What are the caliper specs Ron? 6 piston I take it?
Old 06-25-2010, 03:32 PM
Former Vendor
Yup!
Old 06-25-2010, 04:12 PM
gkmccready
gkmccready's Avatar
Originally Posted by Ron@Vengeance Racing
Factory 18" C6 wheels.
C6 or C6 Z06? I would *love* a chance at fitting C6 non-Z wheels over some real brakes. How thick are the pads used by these calipers? Also, how much are replacement rotor rings? Looks like the C6 kit is AP6000 and AP6050?
Old 06-25-2010, 04:31 PM
Former Vendor
Sorry, meant to say C5Z wheels.
Brake pads are Mintex Xtremes:
http://www.stillen.com/product.asp?id=MNTXXTRP1&c=BR
More information on the 6 piston kit can be found in the following .pdf file.
http://stillen.com/product_files/AP1600R~broch.pdf
Old 06-25-2010, 05:22 PM
mgarfias
mgarfias's Avatar
How'd you cram a 14" rotor under there? I did the math last year and figured I was stuck with a 13.4" max. 'Course that was with a wilwood SL6R (wide5).
You have a link to the caliper specs?
Edit: i'm a moron and didn't see your above post.
Also, the kit uses the CP5555 caliper FWIW.
Old 06-25-2010, 05:26 PM
0Team STILLEN
Former Vendor
Team STILLEN's Avatar
Great work as always! I like the tabs to pretect the lower ball joint and tie rod ends
We can help out with the tech advice and pad selection depending on usage and as a certified retailer and installer for AP Racing, I am sure Ron can get you guys the best pricing possible!
Old 06-25-2010, 08:46 PM
davidfarmer
davidfarmer's Avatar
neither the kit or the caliper pdf seems to list piston sizing.......
Old 06-26-2010, 02:29 AM
fatbillybob
fatbillybob's Avatar
Chris NOT T1 LEGAL! T1 is 4 piston or sl6r as the only legal 6 piston. I already looked at this kit. AP has had it around for a while iirc.
Old 06-26-2010, 11:52 AM
geerookie
geerookie's Avatar
Pads are 18mm.
I will email you the engineering drawing for the caliper. Assuming I can find your email address
Old 06-29-2010, 09:52 AM
Zenak
Zenak's Avatar
on a C5 will they fit under a stock wheel like the Wilwoods? Or does the wheel have to be BBK friendly?
Specifically would they fit under a Fiske FM10 or CCW Classic without spacers?
This is my issue when picking a BBK since everyone runs these rims and so far only wilwoods are friendly under them without spaces.
Old 06-29-2010, 01:19 PM
drivinfast
drivinfast's Avatar
nice brakes and nice ducts, NEED to get heat guards
same setup CCW C14
Old 07-01-2010, 12:45 AM
dvandentop
dvandentop's Avatar
love my ap brakes
Old 07-01-2010, 12:08 PM
Zenak
Zenak's Avatar
Rom will they fit under CCW Classics? Fiske FM10? without spacers?
these are 2 of the most common aftermarkets out there.
Old 07-01-2010, 03:57 PM
drbenne
drbenne's Avatar
with exception of the Wilwood sl6r, I have not found any T1 legal 4 piston racing caliper that will fit with the CCW classic 17 inch wheels. Beautiful brakes .
To AP Racing Track Kit | C5 Z06 | Install/Pictures
Old 07-01-2010, 08:46 PM
hamdog
hamdog's Avatar
Classics don't work with most big brake kits! Had a long conversation with John about this. Most wheels with any significant lip won't do well with big brake kits. I just went through this process upgrading to the C6 Z06 brakes on my C5.
One of the most economical and practical options is running C5 Z06 Speedline 18x10.5 all the way around.
Another great option is the TSW Nurburgrings. Lightweight inexpenisve wheels with a ton of clearance. 18x9 fronts give you a minimum of 1.5" clearance with the C6 Z06 brakes
http://forums.corvetteforum.com/c5-p...group-buy.html
Old 07-03-2010, 10:23 PM
fallen
fallen's Avatar
Location: Upper West Side, NY Very Downtown Houston, TX
Do you have any pix with the wheel on? Thanks.
Old 07-05-2010, 10:32 PM
hamdog
hamdog's Avatar
Here you go!
Quick Reply: AP Racing Track Kit | C5 Z06 | Install/Pictures
