power steering fluid boil over
Hey guys,
My ’08 C6 is not the Z51 version and l am having power steering boiling over issues. After changing to Red Line power steering fluid, I was hoping this would make a difference but it really has not helped. I notice the boil over only happens when I do HPDE road-course events. Once it cracked and GM did replace the reservoir. However I notice it is still overflowing.
I am thinking about hooking up a Z51 heat exchanger, but it looks so flimsly that I am wondering if I actually need something more substantial.
Anyone out there know of a couple different solutions I can try?
Where is the fluid level when cold? When hot? You might try removing some fluid so that when the fluid is hot, the level in the reservoir is at the "Cold" mark.
If you don't have a PS fluid cooler, it sounds like you should add one. Doesn't necessarily have to be a GM cooler, Perma-Cool makes a two pass and a 4-pass cooler that will work. Fluid coming from the return line should flow into the cooler and then out to the reservoir.
Hey guys,
Check the fluid cold it's probably too high mine was. I then switched to redline but it was overfilled again. Although it was overfilled, it didn't boil over as much. I drained some out it's just above the cold line I'll see the results at Laguna Seca in a couple of weeks. I did buy a turn one just in case due to a stock pump failure.
I have the same problem with my 2006 base coupe. I bought a Turn One pump and some synthetic PS fluid but haven't installed it yet. The Turn One pump is less than $200.
Hey guys,
The reservoir is located on the return side of the rack and the suction side of the steering pump, so it should not be over-pressurizing from anything other than the higher vapor pressure of the fluid when at higher operating temps. Changing the steering pump will not solve the preceived over pressure in the reservoir. Lowering you fluid level can help by giving the fluid more room to expand once it heats up.
I'm still using the stock GM steering pump, so I cannot speak as to the durability and effectiveness of the turn 1 pump.
Gotta love the forums. Never heard of this mod but have experienced some overflow myself. Not sure if its to much fluid or true boil over at this point but did find this in my Google search.
http://www.gmhightechperformance.com...all/index.html
Now the question is where do yo buy one? Any vendors on here?
here is my install of the turnone. just google and you will find Jeff and the site. last pics for the larger PS cooler
http://forums.corvetteforum.com/c6-t...t-off-car.html
Zip tie a rag over the top to absorb the excess fluids. The fluid will ruin electronic sensors on the car and cause more problems. Also a good fluid like Joe Gibbs is a good thing to switch to
