Total Oil Capacity w/ Z06 Oil Cooler on 2007 Z51
Old 06-30-2010, 02:26 PM
Rob Willis
Rob Willis's Avatar
Default Total Oil Capacity w/ Z06 Oil Cooler on 2007 Z51
Wondering what my total oil capacity is now with the Z06 external oil cooler?
Factory 2007 Z51 LS2 is 6.5qts with oil filter change.
Thinking at least 6.5 or 7 now?!
Not sure how much that in-radiator side tank held vs the external Z06 oil cooler.
Thanks.
Old 06-30-2010, 02:42 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,398 Likes on 749 Posts
It becomes more or less irrelevant, because once the oil cooler is filled it won't drain down (at least my EOC on my LS1 doesn't). The only way to drain the "old" oil out of the cooler would be to break the system open, which is a lot more hassle and risky than it's worth.
When I change my oil it takes about 6 quarts to the full mark, same as a LS1 without an EOC.
HTH, and have a good one,
Mike
Old 06-30-2010, 02:59 PM
LEAVINU
LEAVINU's Avatar
I fill mine with 7qts.
Old 06-30-2010, 03:01 PM
95jersey
95jersey's Avatar
just for point of reference, my Lingenfelter takes 10 quarts
To Total Oil Capacity w/ Z06 Oil Cooler on 2007 Z51
Quick Reply: Total Oil Capacity w/ Z06 Oil Cooler on 2007 Z51
