Rear Shock Bushing Options?
Old 07-05-2010, 10:25 AM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
Default Rear Shock Bushing Options?
I have Motons on my C6Z and have put poly bushings where I can but they still use the factory rubber shock bushing at the top in the rear.
After 26 hours of track time these bushings are all torn apart. Does anyone make a more durable alternative before I throw another set of rubber ones back in?
Thanks.
Old 07-05-2010, 10:32 AM
dvandentop
dvandentop's Avatar
talk to randy at drm has a set i am sure that would work good. it is more of a poly bushing then the stock rubber
Old 07-05-2010, 11:08 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I do have something that should work just fine for your setup. They are pretty cheap also!
http://dougrippie.com/?p=462
Two of the above part numbers and you are good to go. If they don't work send them back and I will get the cash back to you!
Randy
Old 07-05-2010, 12:11 PM
drivinhard
drivinhard's Avatar
Hardbar also has a nice solution, delrin uppers. very nice
Old 07-05-2010, 12:56 PM
geerookie
geerookie's Avatar
This is a very nice setup. It will work well with the Motons if they are the pin top version.
http://hardbarusa.com/hardbar/produc...roducts_id=141
Old 07-05-2010, 01:11 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Thanks everyone.
Now does anyone know where you can send a Moton to get repaired? I just managed to break the adjuster off the top and shoot the fluid everywhere.
You know when you have the moment when you think you should just walk away and instead you keep going - yeah it was one of those...
Old 07-05-2010, 01:28 PM
Zenak
Terminal Vette Addict
Zenak's Avatar
pfadt nice a nice spherical style rear shock mount bushing now. similar to their spherical control arm ones. Never tried it, my buddy is getting them with his LG GT@ set up. I will wait to see his problems before I get them. Like all solid inserts, you might need to hone the ID of the lower to make these fit so sometimes you need a machine shop or tools to so it right.
Old 07-05-2010, 01:44 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Originally Posted by Poor-sha
Thanks everyone.
There is a man in GA that can do the repair. For the life of me, I can't remember his name or shop.
Randy
Old 07-05-2010, 02:13 PM
Poor-sha
Track Rat
Poor-sha's Avatar
I asked Aaron about this at VIR last week. He said that he didn't have anything that would work with Moton rears. I'm wondering if the pin is an odd size or something (although the stock bushings seem to work).
Also, are the front and rear shock bushings the same? I know that my fronts appear to have a bigger washer on the bottom.
Right now I'm also stuck trying to get the nuts off the top of the pin. It looks like I need an unusually thin wrench so that I can hold the bottom nut while I loosen the top one - all the wrenches I have won't let the top nut turn if I put it on the bottom one.
What a mess...
Old 07-05-2010, 02:15 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Randy
If it comes to you Randy please PM me. I have a mail in to Jason as well.
Old 07-05-2010, 02:56 PM
gkmccready
gkmccready's Avatar
tony@tcdesignfab.com is a certified Moton rebuild guy, as is Bruce at performanceshock.com (there's a Contact Us link there). Should be plenty of other Moton dealers/centers around, too.
Old 07-05-2010, 03:07 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Google will find everything........
Moton Suspension Technology
- www.motonsuspension.com
5174 Performance Drive, Cumming, GA - (770) 886-8777
To Rear Shock Bushing Options?
Quick Reply: Rear Shock Bushing Options?
