Cage Mounting , how many points
How many cage mounting points can you have?
I am thinking eight for what I want to do,
2 through the firewall, 4 point in the car, 2 rear down bars.
the hoop will be mounted to the frame rails, going thru the floor.
For example, following the FIA book for a GT3 cage.
And, I have a steel frame C6
Not the FIA rule book, use the NASA or SCCA Tech rule books.
http://www.nasaproracing.com/rules/ccr.pdf
http://www.scca.com/contentpage.aspx?content=44
as he said, check YOUR sanctioning body for mounting points, tube size, and door requirements. FIA is pretty slim compared to many US organizations. However, your design sounds pretty standard. 6 for the safety cage, plus an option 2 for the forward bars.
Thanks for the info...
I have been reading all of the rule books, if i stay with 1.750 .120 dom tubing I should be ok, all the books are pretty close to the same.
except for the NASCAR bar debacle, it seems pretty straight forward.
to do correct NASCAR bars they need to be tied into the rocker
does that go against the mounting point allowance??
I want to to run in the STU class, and what ever equivalent in NASA.
And it seems I can run my side pipes just like the C6r, as long as the exhaust pipes exit behind the wheel base center line.....
And if anybody knows, can I run Z06 body work with a steel chassis and a LS1 for power?? Ive got a Z06 roof panel also....
Wheels, seem straight forward, 18X11 max front, 18x13 max rear....
Former Vendor
.120 is safe to run in the US for a long time.
Nascar bar attachments do NOT count in class limiting points.
NASA SU you can have the cage tie in to a million spots. I can agrue the need for more then 6 in a class of cars doing 170+ mph.
Side pipes aren't a easy task, many things get in the way. Sure they sound cool, look bad ***, and the cockpit runs cooler. I don't think the average race car needs that.
LS1 power not a problem in SU.
Maybe you should let some that has built a few cars, build yours!
Randy
www.dougrippie.com
Randy
www.dougrippie.com
Yes I wish I could have someone do it, but my wallet is very thin....
Luckily I am capable to do it myself, got a mill,lathe,syncrowave 300,
20 yrs mech exp, and plenty of friends in the performance/racing business, many names you would recognize, just none of them are chassis builders....
Good to hear I can use my LS1, Ive had it for 9 years...
Randy, is that the chassis that Corvette Recyclers has on ebay the one from the steel frame Z06 project??? That was a pretty cool build.
I am trying to do the undoable with this project, build a competitive car
for less than 20k.....Ive always had luck making junk go fast :-)
Nice cage ,
Anyone need mechanical work done? I gotta fund this project somehow...
My backround, GM ASEP graduate...GM master tech, ended up not staying too long in the GM dealerships...did some Lexus a while back and recently, and almost 10 years on Jaguars, ASE Master Technician
with L1 advanced...
Almost two years in Airframe and Powerplant school but who knew in the middle of it 9/11 would happen, so back to the automotive field,
Did some CNC work and programming, have a little machine shop at the house now. Scored a "big" tig welder and learning how to use it...
Was one of the first users of LT1 edit....
Then I took some time away from "having fun" , but now I am ready to have some fun again....
I just need to make some more money :-)
with L1 advanced...
Former Vendor
If you do just plate the nascar bars then you could be over in your attachment points depending on class. points 7/8 which are typically the ones from A piller to firewall are not of great use. Ther is no room to properly place these bars to do their job which is to prevent intrusion to the footwell. Also the vette frame already wraps into this area as you can see if you pull the panel behind the front wheel. I have seen people weld from A piller to the firewall in mostly a staright line from the A piller and the function of which is doubtful. Even if you could bring it to behind the clutch pedal where it belongs there is little support there to weld to. It would be little more than a bar floating in free space.
Even though you have the skil and time, you may find that spending the 4grand for someone else to do the cage, is money well spent. More than cutting, bending and welding tubes together
Good Luck on your project
An experienced cage builder knows the ins and outs, what works and does not work.
Nice cage ,
with L1 advanced...
with L1 advanced...
