Rollmaster or c5r timing chain?
Old 07-07-2010, 03:33 PM
02impactblue
02impactblue's Avatar
Default Rollmaster or c5r timing chain?
I'm putting the ls6 back together and I need a timing chain to replace the broken one. Any recommendations for a reliable chain for a stock ls6 track car?
Old 07-07-2010, 04:20 PM
C5ZEE06
C5ZEE06's Avatar
I decided to go back with another C5R for my rebuild (due to broken chain). Im also installing a Powerbond UD pulley and a LS2 style chain damper. I think the pulley selection may be just as important as the chain.
Old 07-07-2010, 04:24 PM
02impactblue
Will the ls2 chain damper work on a 2002 ls6?
Old 07-07-2010, 04:37 PM
C5ZEE06
C5ZEE06's Avatar
not sure that the bolts holes are present..so may need to drill and tap.
To Rollmaster or c5r timing chain?
Quick Reply: Rollmaster or c5r timing chain?
