Lifting Help Needed PLEASE
I need some help please. I read a great article http://forums.corvetteforum.com/memb...admiral94.html on the how to of lifting safely your corvette, however it was a C5. Can anyone please tell me if the admiral's instructions will work for a C6?
I PMed him but his last activity was in December of 2009. I want to purchase the lumber and build the jack stand lift supports he gives detailed instructions on but I need to know if the diagram and directions he gave are correct for the C6 also. Are the C5 and C6 useing the same lifting locations and are the dimensions the same.
Thanks you in advance for the help. Need to bleed the brakes ASAP and want to lift it safely.
The link doesn't work! Give me a call 772 335 8318 Jim Dillon I put the jack stands under the front and rear cradles. On the rear I jack in the middle of the rear cradle and the same on the front if you have a low enough jack. Otherwise you need to use 2 jacks, one one each side where the jacking points are. JD
Lifting Help - Have the answer
